Tip & How-To about Sony Playstation 3 (PS3) Console
It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan to ON and it's not supported by your TV. Try turning off the Playstation 3 and then hold the power button for about 5 seconds, until you hear a second set of beeps. This procedure will reset your display settings, then auto detect your connection, provided you have kept up with the updates. If you have kept up with the updates or aren't sure, you can use the same steps, but you will need to be connected via Composite Cable and not HDMI. If this doesn't work, you may need to send it in for reparis.
