Tip & How-To about GE 30 in.JP950 Electric Cooktop
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
