Tip & How-To about Kodak EasyShare V530 Digital Camera
Lens not retracting on digital camera.
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Kodak EasyShare V530 Digital Camera Logo
Lens stays out
E18 is lens error. When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Jan 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
lens will not retract. camrea frozen my camera will flicker on and off and the lens will not retract. it is a kodak M763, first time this has happened.
Dec 26, 2008 | Kodak EASYSHARE M763 Digital Camera
Sony Powershot G9 - Lens won't retract
Dec 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
lens will not retract and camera will not work
Dec 08, 2008 | Casio EXILIM Card EX-S770 Digital Camera
lense will not retract even after camera has been charged
Oct 16, 2008 | Kodak EasyShare V530 Digital Camera
3,498 people viewed this tip
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
