20 Most Recent
Vicence Woven Strap Watch Questions & Answers
The weave in the watch
The only thing that I could advise you is contact Vicence directly so they could advice you what to do and where to bring the watch. I believe there are service centers nearby that could fix the watch. You can send them emails or call them. Below is the link to their site.
http://www.vicence.it/contact.asp
MY WATCH JUST STOPPED RUNNING.
Of course the problem may be with the movement, but, if I was working on your watch I would carefully inspect that the battery was put in right and second I would check the conditiion of the battery. It is always possible that the battery may too old. They d have a shelf life. Also, if I were working on your watch I would be able to test the movement to see of the gears in the movement were stuck because of gummy oils, etc. I have the equipment to unstick a movement. The bottom line maybe that you will need the movemet replaced as this is generally much cheaper than the labor to get yours working again. Good Luck
Need a new watch movement
I am not sure which Vincente model you have but I can tell you that the movements for those are Swiss made. That may not seem like much but there's not a lot of info on them.
Chances are it's an ETA movement and if not there's an ETA movement that should fit it. ETA is one of the top Swiss movement makers around. You will find their movements in more watch over $1500 then I care to mention. You should be able to get a movement for around $150 plus installation. You will need to go to a watch repair shop so find a good one.
Hope this helps.
I am a retail jeweler. We broke a cust.'s crystal
This is hard one. First advise is to contact manufacturer. If no success there, then you have to find out any watch repair shop with watch glass cutting services. I used to order obsolete watch glasses to cut over here in England, so, should be similar service in USA. Last and most expensive thing is to buy KRONOGLASS cutting machine, but you will be able to cut watch glasses in the future and provide this service yourself. Not much, but at least you have an idea where to look for. Rate me, plz.
Stem is broken on the watch
take it to a jeweler, but if u have another stem and crown remove the back and look for a small arrow pointing at a how. push down to release remaining parts and then insert the new one
Part of the back cover plate has broken off
You can try to contact the manufacturer for a replacement part-
Orowatch Vicenza - Piazza Castello, 3 - 36100 Vicenza - Italy
Ph. +39 0444 232500 - Fax +39 0444 526155 -
[email protected]I recommend seeing a watch maker/technician. They would have more options for you. Make sure you have the watch brand and case back number available when calling about parts for your watch.
Beautiful watch!
Back of a 9k vicence
Vicence watches are made in Italy, so, the back replacement you can find only through the dealers.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
