20 Most Recent AT&T 1480 Phone Questions & Answers
PHONE JUST A DIAL TONE?
Make sure your phone is in Tone and not Pulse dialing. To change it for your phone, just look in your manual. If you don't have one, I have included a link for you to d/l it.
Manual
11/15/2013 7:39:15 PM • AT&T 1480 Phone • Answered on Nov 15, 2013
manual
1480 Phone Manual
AT&T Lands PhonesUploaded on Oct 28, 2013
Voicemail
You can download the manual here and get all the setup information. Just scroll down 'til you get to your model.
4/9/2009 10:02:08 PM • AT&T 1480 Phone • Answered on Apr 09, 2009
At&t 1480 2.4 ghz new call light keeps flashing
You can download the manual here. Just scroll down 'til you get to your model.
4/9/2009 10:00:29 PM • AT&T 1480 Phone • Answered on Apr 09, 2009
0answers
Jesus Suarez
Be the first to answer 9/8/2008 11:28:59 PM • AT&T 1480 Phone • Posted on Sep 08, 2008Be the first to answer
0answers
My AT&T corded phone 2.4ghz 1480
3 way calling is a feature you get from your phone company. If you already have the service you just need to find out what the procedure is from them.
1/20/2008 12:44:51 AM • AT&T 1480 Phone • Answered on Jan 20, 2008
2answers
AT&T Cordless Phone and Answering machine
Here is a website that has all their manuals. http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
1/2/2008 2:17:27 AM • AT&T 1480 Phone • Answered on Jan 02, 2008
Need the telephone power supply for the 1480
Go to wall mart they hav universal adapters with a bunch of different plug ends and a switch to set the right voltage to your unit.When you get it you have to find the voltage of the phone,it would probabally be on the bottum of the phone base probabally between 7 and 14 volts.This adapter is probabally cheaper then the original and you can use it after you get a new phone for future pet problems.good luck Ps you can also get them at radio shack if you dont like walmart and please leave feed back
9/26/2007 2:49:58 AM • AT&T 1480 Phone • Answered on Sep 26, 2007
Date/time stamp on answering machine
Set the correct date and time by pressing "time/set." Then, follow the voice prompts. Press "time/set" again. Use "change" button to advance day. Press "time/set" again to adjust hour. Use "change" button to advance hour. Press "Time/set" again to adjust minutes. Press "change" button to advance the minutes. Press "time/set" when finished.
9/22/2007 12:50:30 PM • AT&T 1480 Phone • Answered on Sep 22, 2007
AT&T cordless/answering machine: 4695
From the user manual, you need to use the MENU, CHANGE and TIME/SET keys Set the Clock 1 With answering system on, press MENU until the system announces,?Change clock.? 2 Press CHANGE until the system announces the correct day, then press TIME/SET. 3 Press CHANGE until the system announces the correct hour, then press TIME/SET. 4 Press CHANGE until the system announces the correct minutes, then press TIME/SET. The system announces the current clock setting. 5 Press an MBOX/STOP button to exit programming. Hope this helps
8/9/2007 6:58:19 AM • AT&T 1480 Phone • Answered on Aug 09, 2007
2answers
How to clear ALL memory from 4-set of (now disconnected) AT&T Model CL82401??
There is a way to delete all calls in the Caller ID log. With the phone system in standby mode, press Menu/Select (key to the upper right of the arrow keys). Scroll (up/down arrows) to Caller ID log. Press Menu/Select again. Scroll to Del all calls and press Menu/Select. You should see a Delete all calls? Press Menu/Select to confirm. There is no corresponding way to delete all old speed dial or directory listings. The manual for the CL82401 is available here: https://att.vtp-media.com/media/p/document2/products/%7B60627918-4BDE-494D-8537-E265D7649708%7D/CL82201_CIB_2_611.pdf . See page 42 for the information on deleting the caller ID log. See pages 36 and 38 for the directory and speed dial items. I hope this helps. Cindy Wells
12/15/2023 3:52:36 PM • AT&T Lands... • Answered on Dec 15, 2023
2answers
AT&T 1830 phone/answering machine. How do I get a manual please?
Question edited for clarity.
AT&T 1830 User Manual - ManualMachine.com
ManualMachine.com https://manualmachine.com > att > 6453-user-manual ANSWERING SYSTEM TELEPHONE 1830. •Installation. •Telephone Operation. •Memory Dialing. •Answering System Operation. •Remote Operation ...
AT&T Product Manuals ' Product Support Center
AT&T https://telephones.att.com > product-support > manuals Find official user manuals and quick start guides for cordless and corded telephones from AT&T.
AT&T Answering Machine 1830 need manual for at&t 1830
Manuals Online http://phone.manualsonline.com > support > att > need... Aug 9, 2012 - Phone manuals and free pdf instructions. Find the user manual you need for your phone and more at ManualsOnline.
12/13/2023 11:07:52 PM • AT&T Lands... • Answered on Dec 13, 2023
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
AT&T 1480 Phone Logo
24 questions posted
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
t 1480 2 4 ghz new call light keeps
  • Lands Phones
