20 Most Recent AT&T 958 Speakerphone (att26835) Questions & Answers
manual
0answers
I have an AT&T 958
This is a standard phone so I'm assuming you're using this in a home or small office, connected direct to a regular phone line, and that you're using calling services from your phone service provider. 3-way calling works as you describe: you press flash to get dialtone again, call the other party, then press flash again to connect the two so all three of you can talk. The point is that this is 3-way calling, not a forwarding or transfer function. You can't transfer a call to another number this way. Since you initiated the 3-way call, the connection requires you to be there; when you hang up the connection between the other two parties is broken.
Your line may also have call-forwarding, which lets you program a number that calls to your line will reach if you're away (an alternative to using voicemail or an answering machine and needing to check messages). But this doesn't allow you to transfer a current call to another number, only incoming calls.
The only way you can transfer a call is when you have the switching equipment (an office phone system, for example) at your location, and have at least two outside phone lines available. Then the system would allow your phone to disconnect, and still maintain the connection between the other parties. But both of the phone lines would remain tied up until the other parties hung up, and if you only had two lines you'd be unable to receive or make any other calls.
Residential customers with a single phone line don't have any option to transfer calls.
6/8/2011 4:35:50 PM • AT&T 958... • Answered on Jun 08, 2011
2answers
How to clear ALL memory from 4-set of (now disconnected) AT&T Model CL82401??
There is a way to delete all calls in the Caller ID log. With the phone system in standby mode, press Menu/Select (key to the upper right of the arrow keys). Scroll (up/down arrows) to Caller ID log. Press Menu/Select again. Scroll to Del all calls and press Menu/Select. You should see a Delete all calls? Press Menu/Select to confirm. There is no corresponding way to delete all old speed dial or directory listings. The manual for the CL82401 is available here: https://att.vtp-media.com/media/p/document2/products/%7B60627918-4BDE-494D-8537-E265D7649708%7D/CL82201_CIB_2_611.pdf . See page 42 for the information on deleting the caller ID log. See pages 36 and 38 for the directory and speed dial items. I hope this helps. Cindy Wells
12/15/2023 3:52:36 PM • AT&T Lands... • Answered on Dec 15, 2023
2answers
AT&T 1830 phone/answering machine. How do I get a manual please?
Question edited for clarity.
AT&T 1830 User Manual - ManualMachine.com
ManualMachine.com https://manualmachine.com > att > 6453-user-manual ANSWERING SYSTEM TELEPHONE 1830. •Installation. •Telephone Operation. •Memory Dialing. •Answering System Operation. •Remote Operation ...
AT&T Product Manuals ' Product Support Center
AT&T https://telephones.att.com > product-support > manuals Find official user manuals and quick start guides for cordless and corded telephones from AT&T.
AT&T Answering Machine 1830 need manual for at&t 1830
Manuals Online http://phone.manualsonline.com > support > att > need... Aug 9, 2012 - Phone manuals and free pdf instructions. Find the user manual you need for your phone and more at ManualsOnline.
12/13/2023 11:07:52 PM • AT&T Lands... • Answered on Dec 13, 2023
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
Standby mode At&t CL8`301
Do you mean the AT&T CL81301 Cordless telephone? This model doesn't have an answering system. You'd need to adjust the number of rings for your voicemail system through the telephone company's system. See the manual here: https://att.vtp-media.com/media/p/document2/products/%7B40A22BFC-681D-46DC-B836-7CB7C7A691FE%7D/CL81101_CIB_5_610.pdf . If you mean the AT&T CL82301 or the CL83301, first make sure that the system is set to Answer On. Do this with the base Answer On/Off button or through the Menu system (see below for accessing the Answering System menu). You'll need the Answer On/Off line in the handset menu. With the phone system idle (no calls in or out, no one using another handset), press Menu/Select. Use the Up(DIR)/Down(CID) arrows to navigate to Answering Sys. Press Menu/Select. Navigate to Ans Sys Setup and press Menu/Select. Navigate to # of Rings and press Menu/Select. Use the up/down arrows to choose the number of rings and press Menu/Select to Save. Press Off/Cancel to exit the menu system. The manual for this cordless telephone system is available at ManualsLib, https://www.manualslib.com/products/AtAndt-Cl82301-165464.html . See page 47 of the manual, https://www.manualslib.com/manual/643600/AtAndt-Cl82101.html?page=53#manual . Note: if you choose Toll Saver, the answering system will pick up after two rings if you have new messages. It will pick up after 4 rings if there are no new messages. I hope this helps. If you have a different AT&T CL8 * 301, please add a comment with the correct second digit in the model number. Cindy Wells
8/22/2021 9:58:57 PM • AT&T Lands... • Answered on Aug 22, 2021
I need phone manual for AT&T 847. How to assign extension to this model?
http://www.radiomanual.info/schemi/YAESU_HF/FT-847_user.pdf
5/6/2020 7:42:43 PM • AT&T Lands... • Answered on May 06, 2020
I need to purchase a replacement manual for the AT&T TTY 8840 Telephone
actually you can get the manual for free at manuals lib.com
1/27/2020 6:47:56 PM • AT&T Lands... • Answered on Jan 27, 2020
My AT&T landline has no dial tone
Is this just for your home or do your neighbours have the same problem? I hope I can help you further, a few more details would help me be able to help you.
Regards Jem
9/22/2019 11:01:20 PM • AT&T Lands... • Answered on Sep 22, 2019
Whenever I place a call and am asked to dial an extension , I keep getting the message to enter the number and am unable to complete the call.
Do you hear tones when you press the buttons to dial?Many phones have the option to dial by pulses instead of tones. Make sure your phone is set to tones.
5/13/2019 1:40:49 PM • AT&T Lands... • Answered on May 13, 2019
I need access code to get to voice mail on answering machine - I have at&t dect 6.0 model SL82318
If you need the remote access code for the answering system, then the original (default) access code is given in the manual on page 50 (page 53 of the PDF) and on 55 (page 58 of the PDF). See the manual online at https://att.vtp-media.com/ecp/documents/product_Product/364/UserManual/5977/SL82118_manual_i10.pdf . Unfortunately, if the remote access code has been changed, the default code will not work. As far as I know there is no way to reset the SL82318 remote access code to the factory default remotely. See page 50 of the manual to reset the phone's access code when you are using the handset. When you use the handset and start to change the code, the current remote access code will be announced first. Any voice mail system would be accessed using the phone number and codes from your telephone service provider. This information will not correspond to the answering system of the SL82318. I hope this helps. Cindy Wells
3/16/2019 3:01:40 PM • AT&T Lands... • Answered on Mar 16, 2019
Unable to get a dial tone on my never used att cordless phone my uniden which is on the same line has a dial tone
Reverse the polarity of the phone wires. -Some phones are sensitive to this; others do not seem to mind. I believe you should reverse the red and green.
2/3/2019 7:30:25 PM • AT&T Lands... • Answered on Feb 03, 2019
AT&T 958 Speakerphone (att26835) Logo
Popular Tags
9 questions posted
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
amp t 958
  • Lands Phones
