Hello Terry, thanks for your inquiry!
From the information you have provided the temperature is not holding at 0°F inside of your Frigidaire refrigerator. Is your freezer currently cold? Does anything display on the front of the refrigerator? You may need to perform a reset on your refrigerator and you can do that by disconnecting the power cord for at least ten minutes. If this does not help resolve your issue I would recommend seeking help from a professional technician for proper diagnosis. This will help you avoid any unnecessary part purchases. -Matt
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
JustAnswerhttps://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes.
Sabbath Mode is turned ON and OFF by pressing
and holding both the freezer "? Down" and refrigerator "? Up"
indicators for five (5) seconds. The display shows "Sb"
while in Sabbath mode
https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
Question edited for clarity.
It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below.
The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem.
Aug 22, 2022
Does ir look the same as this FRT18?
https://www.ajmadison.com/cgi-bin/ajmadison/FRT18G6JW.html
Refrigerator Capacity: 14.13 Cu. Ft.
Freezer Capacity: 4.07 Cu. Ft.
Total Capacity: 18.2 Cu. Ft.
Width: 29 5/8 Inch
Depth: 33 5/8 Inch
Depth with Door at 90°: 59 7/8 Inch
Height: 66 1/8 Inch
No. of Shelves: 2
Gallon Door Storage: Yes
Water Dispenser: No
Broken wire? Faulty mainboard?
You can test for power with your digital multimeter or with an electrical proximity tester. Also check the wall socket with something known to work, like a table lamp, phone charger or a vacuum cleaner.
Call for service. If it is the mainboard, you need the correct diagnosis and warranty on the part and the labour.
Apr 24, 2022 - To put a Frigidaire refrigerator in demo mode, hold the Energy Saver and Adjust Freezer buttons at the same time. Press them for three seconds ...
1 answer · Top answer: great !, Happy to help !
