20 Most Recent
ASK Proxima DP6860 Plus Multimedia Projector Questions & Answers
How do i flip the
it's been a long time since I worked on one of these,but if you select the menu and look thru the settings, you should see "ceiling" with a checked box next to it. just uncheck the box.
Multiple reddish pink vertical lines going from
take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
Can the bulb out of Proxima DP6860 work in a
No they will not interchange.
The DP6860 takes a bulb number LAMP-030 and is a 250 watt bulb.
The DP6850 takes a bulb number LAMP-017 and is a 190 watt bulb.
If you could physically make them fit by some means, likely just the wattage difference would cause problems with the projector. These bulbs require much more electronics to light up than what a normal household bulb does. I'm assuming the projector would think the lamp is either burned out or worst case cause damage to the power supply in the projector.
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Yellow circle
there is a light filter on the blue lcd panel that is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical emgine.
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dim Image
Check you manual for a dual brightness control that may be activated or even stuck at low level.
The manufacturers web site may have a technical help team to consult - have you tried?
I am in Lagos, Nigeria. Where can I get the Remote Control for the ASK Proxima C510 LCD projector? I need it to unlock the key pad urgently
To find a remote control for the ASK Proxima C510 LCD projector in Lagos, Nigeria, you can try the following options:
1. Authorized Dealers: Contact authorized dealers or service centers for ASK Proxima projectors in Lagos. They may be able to provide you with the remote control you need or guide you to the nearest store that carries ASK Proxima accessories.
2. Electronics Stores: Visit local electronics stores that specialize in projectors, audiovisual equipment, or general electronics. Inquire if they have the ASK Proxima remote control in stock or if they can order it for you. Popular electronics stores in Lagos include Slot, Konga, and Jumia.
3. Online Retailers: Explore online platforms that sell electronic accessories, such as Jumia, Konga, or other e-commerce websites specific to Nigeria. Search for the ASK Proxima C510 remote control and check if it's available for purchase. Make sure to choose a reputable seller with positive reviews.
4. ASK Proxima Customer Support: Reach out to ASK Proxima directly through their customer support channels. They can provide information on authorized distributors or suggest alternative options to obtain the remote control you need. Visit the ASK Proxima website or search for their official contact details online.
Remember to provide specific information about the model and brand of your projector when contacting sellers or customer support. This will help them assist you more accurately in finding the right remote control for your ASK Proxima C510 LCD projector.
