20 Most Recent
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Questions & Answers
Thin twin washer basket is VERY off balance and once a cycle runs, there is water filling up under the washer / spin basket.
You should be able to put it in spin and remove the water. if it don't you have a problem somewhere. There should be 3 springs hooked to the bottom of the tub to hold it on center if one breaks or comes loose it will be off balance. If you get water in the tub when not useing it and the water is on from the water line the water valve is leaking.If the water don't shut off when filling the water level switch could be bad.or the tube running to it could be stopped up pull the hose off the water level switch and blow through it if it bubbles in the tub it is ok. If can't blow through it it is stopped up.Hope this helps
7/16/2018 7:31:39 AM •
Whirlpool...
Answered
on Jul 16, 2018
