20 Most Recent Casio PhoneMate PMP3875BK Questions & Answers
2answers
When someone calls, the machine
usually this kind of problem arises when the memory on which the messages are being stored is either corrupt or filled up. In such situations it is best for you to try and delete previous messages which have been stored on the unit. If there are no previous messages then apparently it is the memory which is bad. Although the battery could also be low and therefore cause these kind of problems but since you said the batteries are in then i am sure you trust the integrity of the batteries.
To sort out the bad memory problem you have to send the unit to the local dealer to get you a repairer to either try and format the memory stick or if need be replace it.
Hope this solution has been helpful?
4/21/2011 7:14:37 AM • Casio PhoneMate... • Answered on Apr 21, 2011
I have the phonemate 2970
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
2/18/2011 1:09:08 AM • Casio PhoneMate... • Answered on Feb 18, 2011
I need the adapter M/N-75 for the casio phone mate
If you need this adapter still, I have just posted one on eBay.
4/5/2010 5:32:56 PM • Casio PhoneMate... • Answered on Apr 05, 2010
Retrieving messages from answering machine phonemate 8500
I think the default access code for the 8500 is 123; But I'm not sure if # or * has to be entered first; try all three?
5/6/2009 7:10:27 PM • Casio PhoneMate... • Answered on May 06, 2009
Need 3.6 volts 600 matt battery
Here is a site that will help you just find out what model number it is.
http://www.batteryvalues.com/PhoneMate-cordless_phone-models.aspx
1/6/2009 10:19:03 PM • Casio PhoneMate... • Answered on Jan 06, 2009
Programming mulitple mailboxes
I threw the phone in the trash...
3/31/2008 11:24:26 PM • Casio PhoneMate... • Answered on Mar 31, 2008
The one hole outgoing message tape will it work on a 4200 and a 4300 Casio phonemate answer machine?
To determine if the one-hole outgoing message tape will work on your Casio Phonemate models 4200 and 4300, I recommend the following steps:
  1. Check User Manual: Consult the user manual or documentation for your Casio Phonemate models. Look for information about compatible tape formats, sizes, and specifications. The manual may provide guidance on the type of tape that can be used for outgoing messages.
  2. Contact Customer Support: Reach out to Casio customer support or the manufacturer's official website for information about tape compatibility for the models 4200 and 4300. They should be able to provide specific details about compatible tape types.
  3. Trial and Testing: If you have access to the one-hole outgoing message tape, you could try testing it on the models 4200 and 4300 to see if it functions correctly. Make sure to follow any installation instructions provided in the user manual.
  4. Seek Expert Advice: If you're unsure about compatibility or encounter any issues, consider seeking advice from experts who specialize in telecommunication equipment or the specific Casio Phonemate models.
8/5/2023 10:20:58 AM • Casio Lands... • Answered on Aug 05, 2023
How to reset a Casio WK-500 electric piano/keyboard to Factory Default?
Fit a new screen and it will be working again or replace it; here is one as an example https://www.ebay.co.uk/itm/393777215771?hash=item5baef3791b:g:GRIAAOSwALVhsdsB
12/31/2021 2:10:49 PM • Casio Lands... • Answered on Dec 31, 2021
I have a Casio T115 phone answering machine,how do I set it to answer after 5 rings?
There should be a button that says setup. If you push that it will tell you what to do, Ours does that.
4/2/2019 8:14:09 PM • Casio Lands... • Answered on Apr 02, 2019
How to set time and date on a Casio Phonemate answering machine
Look up in user's manual. You don't have one? Get it from here http://www.casio.com/support/manuals/telephones/ta117.pdf
7/3/2015 11:38:09 PM • Casio Lands... • Answered on Jul 03, 2015
I need the 3 digit remote access code for my Casio answering machine. it is not on the bottom as suggested, only directions for setting the time and date, etc. Thanks.
press the set/check code and they should tell you what your codes are, but the default code could be 1 2 3
1/20/2015 5:58:22 AM • Casio Lands... • Answered on Jan 20, 2015
What kind of battery does this phone use for handset
The model number should appear on the base of the phone and you can remove the old battery to see the type to replace it with.
4/6/2014 2:59:43 AM • Casio Lands... • Answered on Apr 06, 2014
0answers
3answers
Owners manual for casio phonemate TA140. Info on remote access
I have a casio/phonemate TA 140 answering machine but no owners/user manual. Where can I download a copy?
12/8/2013 10:49:58 PM • Casio Lands... • Answered on Dec 08, 2013
Casio PhoneMate PMP3875BK Logo
20 questions posted
Top Casio Lands Phones Experts
ADMIN Eric
ADMIN Eric
Don A
Don A
Arun Deep
Are you a Casio Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Casio Lands Phones
  • Casio Lands Phones
Most Popular Question
programming mulitple mailboxes
  • Lands Phones
