20 Most Recent 791XV The 791XV is a 2-way Security and Remote Start system. Th Questions & Answers
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
791XV The 791XV... | Answered on Mar 03, 2015
Why not May need an extra key copied get schematic wiring instruction are available for instalation of system to this car just need to follow inst.very carefull check color codes on wires twice
791XV The 791XV... | Answered on Dec 23, 2013
bring back to where you purchased it. Like asking why is my tire flat - lots of answers to that one.
791XV The 791XV... | Answered on Jun 08, 2012
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
791XV The 791XV... | Answered on Jul 23, 2011
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
791XV The 791XV... | Answered on Jan 30, 2011
The parking light flashes are a diagnostic report to alert you to the reason the remote starter is not working:
5 flashes; brake wire is active
6 flashes; hood pin is active
7 flashes; manual transmission mode is enabled and not initialized
8 flashes; neutral safety wire has no ground or the switch is OFF.
Count the flashes and you will be able to go directly to the problem. Enjoy.
791XV The 791XV... | Answered on Nov 27, 2010
Open the door, key to ON position,within 5 secs press the valet button one time, then press AND HOLD it the second time. While holding press the Lock button on the spare remote. Let go and turn off the car...your done.
791XV The 791XV... | Answered on Nov 11, 2010
Hi! As a first course of action please remove the positive battery connector and let it sit for 5mins. then reconnect it. This will reset the system and can get rid of the problem. Please write back on the progress.
791XV The 791XV... | Answered on Oct 26, 2010
The original remote is the 479V; you can also use the 472V.
791XV The 791XV... | Answered on Oct 20, 2010
there was a recall on these units for the antenna. Unplug the antenna on your windshield, let it sit for 5 minutes then plug it back in. You will need to contact your authorized dealer to replace it under warranty if you are the original owner of the system.
791XV The 791XV... | Answered on Aug 14, 2010
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngmoz-screenshot-3.pngmoz-screenshot-4.pnghttp://forum.ecoustics.com/bbs/messages/4/207788.jpg
click on this link
very big install job good luck
need anymore help feel free to email me
sonicboomelectronics@hotmail.com
please rate this repair thanks
791XV The 791XV... | Answered on Aug 03, 2010
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
Popular Tags
62 questions posted
Top Viper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Larry Tezekjian
Larry Tezekjian
david griffin
david griffin
Level 1 Expert
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Viper Vehicle Parts & Accessories
Most Popular Question
replace
  • Vehicle Parts & Accessories
