20 Most Recent
4-Button Remote Start/Keyless Entry with DP II Technology Questions & Answers
How to program a crimestopper remote control model
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming
from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few
seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you
are programming, the lights should flash after ever button push. After
all four codes (buttons) are learned, the unit will exit code learning
mode. If not, turn off key and close hood. Hope this helps......BUZZ
Crime stopper remote start, panic activates with remote start
try and reprogram the remote buy looking under your dash and getting the model number of the unit then go to www.crimestopper.com and choosing the support tab then choosing manuals and manuals again using the model number from under the dash find yours you can also contact tech support at
800.998.6880 ext 210
Malibu 2003 remote opener does not work.
I've never seen a remote repaired successfully. I'm not sure why, it just doesn't seem to work. I wonder if the circuit board isn't flexing a little bit, and that dislodges the battery retainer. The flexing, in turn, might also cause microscopic cracks in the circuit board which causes it to work intermittantly.
Reset keypad 05 malibu
2005 malibu remote starter (factory installed) does not work. Lights flash but car will not start. Any suggestions?
Thanks.
1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
Ezee start 90 on 2000 intrepid,unlock feature does
I am almost positve that your 2000 intrepid has one wire door locks, meaning there is one wire that goes to the factory lock module and is hit with different resistance values for lock and unlock. this is tricky. you have to find out what the two different resistance values are, and use two resistors inbetween the alarms lock wires, and the wire you hook to in the car. Stop by your nearest best buy, the guys in the install bay will probaly look up the info for you. I know I would at my shop.
