20 Most Recent
Crimestopper RS1505DP CoolStart(TM) FM/FM Remote Start System with Two 5-Bu Questions & Answers
I have a 95 yukon and my auto start will make the
It sounds like your security bypass isn't programmed or needs to be replaced. Try to reprogram it and then start the vehicle. Shut it down and try to start it a second time, if it doesn't start the second time the bypass needs to be replaced.
Need a good diagram and insructions on the wiring
The Trailblazers can be tricky. First off you will need a digital data bus interface inorder to connect to the power locks etc. Try an Omega DB-GMDLBP module or equivalent. You also have to bypass the Passlock 2 system. If you are not a professional installer I highly recommend you letting a pro do this one for you. I cant upload the chart here but you can find it at
www.the12volt.com
I have a Crimestopper rs-3. I have had 2 instances
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
The vehicle starts with the remote but not with
It sounds like the ignition switch is shot. Part of the security of a remote start system is that, unless the key is in and turned, it'll shut down if the brake is pressed (since the brake has to be pressed to put it in gear to drive). If you put the key in, turn it, and hit the brake, and the car stops, or if you turn the key and it doesn't start, it means the ignition switch (the electronic portion, not the barrel where you stick the key - the electronics are on the backside of the barrel) is not recognizing that the key is in. I'd replace the ignition switch and try again. It's not a keyed part - you can go to a salvage yard and get one to install. You'll have to remove the trim for your steering column and then you'll see the switch on the back of the key cylinder. Should be a couple screws that mount it and a harness that plugs into it, and it'll come right off.
Remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Crimestopper SP502 usb remote wont hold charge
If your Crimestopper SP502 USB remote isn't holding a charge, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
- Check the Battery: Make sure the remote's battery isn't damaged or worn out. If the battery is old or not functioning properly, it might not hold a charge. If possible, replace the battery with a new one and see if the issue persists.
- Charging Cable and Port: Ensure that you are using a functional charging cable and connecting it to a working USB port. Sometimes, the issue might not be with the remote but with the charging equipment.
- Cleaning: Sometimes, debris or dirt can accumulate in the charging port of the remote, preventing a proper connection with the charging cable. Gently clean the charging port using a small brush or compressed air.
- Resetting the Remote: Try performing a soft reset on the remote. This might involve holding down certain buttons or combinations of buttons for a specific duration. Refer to the user manual for your Crimestopper SP502 for instructions on how to do this.
- Firmware Update: Check if there's a firmware update available for your remote. Sometimes, firmware updates can improve the device's performance and battery life.
- Contact Customer Support: If none of the above steps work, consider reaching out to Crimestopper's customer support for assistance. They might be able to provide further troubleshooting steps or suggest a solution.
- Battery Calibration: In some cases, calibrating the battery can help improve its performance. Fully charge the remote, then use it until the battery is completely drained. Repeat this process a couple of times to see if it helps the battery hold a charge better.
- Replace the Remote: If the remote is still not holding a charge after trying the above steps, it's possible that there's an internal hardware issue. In this case, you might need to consider replacing the remote.
Remember that the specific steps you should take may vary depending on the model of your Crimestopper SP502 remote and the instructions provided in its user manual. If you're uncertain about any step, it's a good idea to refer to the manual or seek assistance from the manufacturer's customer support.
Vehicle wont start with sp101 alarm
under the dash by the steering column you will see some wires that dont belong and a small black box about a inch square two wires will go up and into the steering column there will only be two that come from the box cut the wires that go to the box and connect them together its the starter disable . removing the blk box it should start
How do i reprogram my remote?
Sometimes if you press both remote buttons on a transmitter at the same time next to the vehicle for more than 10 seconds it will reprogramme a remote
Renault Megane is draining the battery over night,
I would have your alternator and battery checked after doing a simple inspection of all your power functions. If something is draining the battery fully overnight your battery may not be getting fully charged, or the battery may be old. If the vehicle only does city driving - then once a week you need to dive the vehicle at least 20 minutes of straight driving so the battery gets charged more than it needs for everyday operation of the vehicle.Simple inspection: Check all electronic devices from radio, tv, phone chargers, interior lights are working properly and fully shut off. If a switch is half way, example; interior lights set from "door to on" the light may not be on - but there is a slight draw all the time on the battery.Once we had our dashboard light on all the time but it was turned down so faint with the dimmer switch you could not tell it was actually on. It seems like a simple thing but it drove us crazy for two days until we discovered what was up.If everything checks out then you need to see a mechanic. One thing you can look for under the hood or dashboard is that all wiring is properly sheathed and there is no damage to the insulation around the wires. Again, have them inspect the alternator, (battery charging system), and the battery. An alarm system by itself should not be that taxing to drain your battery overnight.Best of Luck.
