20 Most Recent Fujitsu 18R1 Air Conditioner Questions & Answers
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Fujitsu 18R1 Air... | Answered on Nov 21, 2013
Are you sure you have the batteries in correctly? This is a common mistake so please take a minute and verify it.
Fujitsu 18R1 Air... | Answered on Jul 03, 2012
Taking it out is a very difficult process and if you try you will wish that you didn't...I don't know which end of the globe you live in, but hopefully you are in the northern hemisphere, so you are approaching winter and will not need it...
Once cooling is over, take a small spray bottle and fill it half full of Clorox unscented bleach and the other half water...then spray the fan, soaking it well with the bleach water and moving it around by hand so that you get the whole fan...make sure to catch any run off and protect walls, carpets and such from the over spray, so you don't bleach them...
Then let everything sit and dry out....a few days should do the trick...then take compressed air and blow the dried residue that is left out of the fan blades...
Now you have a clean mildew free fan again...
heatman101
Fujitsu 18R1 Air... | Answered on Sep 25, 2011
HI,
Your drain line is almost clog up. Please check and has it cleaned completely.
Regards, Jay
Fujitsu 18R1 Air... | Answered on Jan 27, 2011
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Fujitsu 18R1 Air... | Answered on Jul 15, 2010
Simplest thing to do is get an air compressor and clean the outside aircon condenser. This if blocked will cause cooling and heating problems. Not to forget to clean the inside evaporator filters as well.
Fujitsu 18R1 Air... | Answered on May 21, 2010
Hi, It is a 25,000 dollar find to bleed off the freon. This is why we have recovery machines. You can pump it down and save the freon that is in the whole system. Go to the outdoor unit. Leave the power on. The small copper line where it comes out of the unit will have a valve on it. It may have a cap screwed over its top. you will see an allen head screw on it. This may take a little time but is well worth it. Screw it down closed, CW. tight. Start the ac and let it run.Since you have no gauges to watch it pull the freon from inside the house to store it all in the outdoor unit, the condenser will shut down when it is done. Once the valve is off and you turn on the stat to run, it won't take very long for the freon to pump in the outdoor unit. We call this pumping the unit down. When done, close down the valve on the large copper line the same way before you shut off stat. Now, you save youself some $ as the freon can be used again. It is perfectly good. The tech will need to cut the lines and relocate them where ever you move this unit and resolder them with silver solder15%. New control wire and move electrical. I hope this has helped you. This is the way it is done. Keep me posted. Merry Christmas,
Shastalaker7
Fujitsu 18R1 Air... | Answered on Dec 24, 2009
Try Encompass Parts Distr. 1-800-638-3328
Fujitsu 18R1 Air... | Answered on Dec 17, 2009
see if you can get it at Homedepo.they do have also universal
Fujitsu 18R1 Air... | Answered on Sep 08, 2009
Heating & Cooling Logo
28 questions posted
Top Fujitsu Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Marvin
Marvin
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Heating & Cooling
Most Popular Question
water leak in indoor
  • Heating & Cooling
