20 Most Recent
Kettler AXOS Cross P Elliptical Trainer" Questions & Answers
Changed batteries for kettler coach LS but still the display doesnt work
If you've changed the batteries in your Kettler Coach LS rowing machine's display unit and it still doesn't work, there could be a few potential issues causing the problem. Here are some steps to troubleshoot:
- Check Battery Orientation: Ensure that the batteries are inserted correctly with the correct polarity (+ and -). Sometimes, even if the batteries are new, they may not make proper contact if they're not inserted properly.
- Inspect Battery Compartment: Look inside the battery compartment for any signs of corrosion or damage. Corrosion can prevent proper electrical contact and cause the display unit to malfunction. If you see corrosion, clean the contacts with a cotton swab and some rubbing alcohol.
- Test Batteries: Even if the batteries are new, they could be defective. Try testing the batteries with a battery tester or multimeter to ensure they have sufficient charge.
- Reset Display Unit: Some electronic devices have a reset function that can help resolve issues. Try resetting the display unit according to the instructions in the user manual. This often involves holding down a specific button for a few seconds.
- Check Power Connection: If the display unit is powered by an external power adapter, ensure that it's plugged in securely to both the display unit and the power outlet. Test the power outlet with another device to ensure it's functioning properly.
- Inspect Display Unit: Carefully inspect the display unit for any physical damage, such as cracks or broken connections. Damage to the display unit itself could be preventing it from functioning properly.
- Contact Customer Support: If you've tried the above steps and the display unit still doesn't work, it's possible that there is a more serious issue with the unit. Contact Kettler's customer support for assistance. They may be able to provide further troubleshooting steps or arrange for repairs if necessary.
By following these steps, you should be able to identify and potentially resolve the issue with the display unit on your Kettler Coach LS rowing machine.
Kettler pacer treadmill energy saving in middle of workout
I'm sorry to hear that you're experiencing issues with your Kettler Pacer treadmill. The sudden stops, display turning off, and the energy-saving light being on could indicate a few possible problems. Here are a few things you can check and try to resolve the issue:
1. Power source: Make sure the treadmill is properly connected to a stable power source. Ensure that the power cord is securely plugged into an outlet and there are no loose connections. You can also try plugging the treadmill into a different outlet to rule out any electrical issues.
2. Safety key: Check if the safety key is properly inserted into the console. If the safety key is not fully inserted or is loose, it can cause the treadmill to stop abruptly. Make sure it is securely in place.
3. Overheating: Treadmills have built-in safety mechanisms to prevent overheating. If the motor or other components of the treadmill get too hot, it may shut off to protect itself. Check if the area around the treadmill is well-ventilated and free from any obstructions. Ensure that the cooling fans on the treadmill are working properly. If the treadmill is placed on a carpet, consider moving it to a hard surface to improve airflow.
4. Motor and belt: Inspect the motor and belt for any signs of wear or damage. A worn-out belt or a malfunctioning motor can cause the treadmill to stop suddenly. If you notice any issues, such as fraying or slipping of the belt, or strange noises coming from the motor, it may require professional servicing or replacement.
If the above steps don't resolve the issue, it's recommended to contact the manufacturer's customer support or a professional technician who specializes in treadmill repairs. They will be able to provide specific troubleshooting steps or schedule a service visit if necessary.
Remember to always prioritize your safety and follow the manufacturer's instructions when dealing with treadmill issues. I hope you're able to get your treadmill working smoothly again soon!
Kettler Treadmill not working right.
If your Kettler treadmill is not working correctly and you have to press Start and Speed + - to start, and it goes back to a pace of 6km/h after 30 seconds, there could be a few possible causes:
- Check the control panel: Make sure that the control panel is functioning properly and that the buttons are not jammed or stuck.
- Check the speed sensor: Make sure that the speed sensor is functioning properly and that it is not blocked or damaged.
- Check the incline sensor: Make sure that the incline sensor is functioning properly and that it is not blocked or damaged.
- Check the main board: Make sure that the main board is functioning properly and that it is not damaged or malfunctioning.
How do i fix kettler unix p error 02?
To fix the Kettler Unix P error 02, you will need to check the system logs for any errors or warnings that may be related to the issue. You may also need to check the system configuration settings to ensure that they are correct. If the issue persists, you may need to contact Kettler support for further assistance.
My kettler treadmill track s6 / alpha run 400 (in others countries), suddenly stop with E5 code in the console.
E5 error code on a Kettler treadmill typically indicates a problem with the motor controller. This could be caused by a number of issues, including a faulty motor controller, a problem with the motor itself, or an issue with the wiring.
Here are a few steps you can try to troubleshoot and fix the problem:
- Check the wiring: Make sure all of the wiring is securely connected and there are no visible signs of damage, such as frayed or exposed wires.
- Check the motor controller: Make sure the motor controller is properly installed and functioning correctly. You may want to consult the owner's manual or a professional for help with this.
- Check the motor: If the motor controller and wiring seem to be in good condition, the problem may be with the motor itself. You may need to have it inspected or replaced by a professional.
If you are unable to resolve the problem on your own, it is recommended to contact a qualified service technician or the manufacturer for further assistance. It is important to follow the manufacturer's instructions when attempting to repair or troubleshoot your treadmill to avoid causing further damage or injury.
Cross trainer. Why isn't display working?
If your elliptical trainer does use an electrical outlet for the power supply, unplug your elliptical trainer and then check the power cord. Replace the power cord if it is frayed or damaged . If the power cord is intact and properly connected to the console, then you might have to replace the console when the elliptical display screen is not working.Or the screen could be broken and needs to be replaced.
How to change the battery in a Kettler Astro cross trainer
The cross trainer takes two AA batteries which are in a compartment behind the display. To replace them, remove the large screw on the underneath of the cross trainer behind the display and the display will lift out easily. The battery compartment is on the back and after replacing the batteries and the compartment cover, put the display back into its slot and screw it back in.
