20 Most Recent
NEC DTU 8-1 Corded Phone Questions & Answers
How do i change the time
Depending on how old your system is try
To set the system Time:
1. Press the SPK key.
2. Dial 828.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00-60).
5. Press SPK to hang up.
Looking for a copy of
Try and Google the manuel, or visit the product's site. That's maybe your best bet.
Nec etw 8-2 wont work at home?
Sorry, but there is no way to get this phone to work on your normal residential phone jack. It was designed to be used as part of a key system, which requires the control system (also called the KSU). The phones are a proprietary digital design and only work when attached to the proper KSU. Unless you want to try locating the rest of the system on eBay or purchase through some other vendor, all you can do with the phone is use it as a paperweight.
Connect/Program Headset
Sure you can do it. as long as the headset has a plug for the handset your fine. Plug it in and you will have to pick up and hang up the handset as needed. The headset key eliminates you having to pick up and hang up the handset to answer with the headset.
Intercom
you can press the speaker button when the phone rings and you will talk over speaker. make sure the mic light is on so the caller can hear you.
Can I forward this phone to my cell phone?
The trick is an access code for call forward all. maybe 47, 46, 45, depends on what type of system it is. But than the other trick is that it has to be allowed to call forward off net in class of service.
Change/reprogram extensions
The easiest way to do this is move the cross connect in the closet. Get the jack number from each location and swapped the cross connect(wire). You could change the extension number in MB4-10 but it depends on the type of system you have.
Extension Name
so,first find out what is the port of this 106. by go to 106.it has to be a display phone.press feature then 4. it probably show 106 tel 07. so your ext port is 07.
go to any display phone. press feature #0*8974.show program mode.now press line 4 then number 18.show 01/18. name of ext.now you press **** 4 times then press 07.show 07/18 sta name.now you can use the key pad to enter mat.press hold to deleted any digit.agter you done press TRF then speaker to exit.
good luck.
Speakerphone does not work
Try pressing the Feature button and dialing the digit 1. This will turn the microphone on and the MIC lite should turn red. Don't lift the handset or press Speaker, just press Feature 1. This will also turn the MIC off if you want it disabled again.
