20 Most Recent Motorola Mobility Droid RAZR HD Questions & Answers
Have you tried to perform a HARD RESET on your phone?.
to do this you first need to power off your phone.
With your phone POWERED OFF press the VOLUME UP and VOLUME DOWN keys AT THE SAME TIME. Once you have depressed BOTH VOLUME KEYS press and hold the POWER key.
Once you have depressed ALL 3 KEYS ON THE SIDE OF THE PHONE the "BOOT MENU SCREEN" should appear.
When the "BOOT MENU SCREEN" appears, release ALL keys select the "RECOVERY" option, the phone will re-boot and you will see the "Motorola" logo. Eventually the "Motorola" logo will be replaced by the "ANDROID IN DISTRESS SYMBOL" (the "ANDROID" with an exclamation point in front of him). Press ALL 3 keys on the side of the phone once again, tap and release the VOLUME UP key, you should then see a BLUE MENU SCREEN,
oNCE YOU SEE THIS blue menu screen SCROLL DOWN TO THE "wipe data factory reset" OPTION.
oNCE YOU HAVE SUCCESSFULLY COMPLETED THESE STEPS THE hard-reset PROCEEDURE WILL BEGIN. WARNING THE HARD RESET PROCEEDURE WILL ERASE ALL OF THE DATA THAT IS CURRENTLY STORED ON YOUR PHONE SUCH AS PICTURES, MUSIC, YOUR CONTACT LIST and so on. SO YOU SHOULD DO A BACKUP BEFORE YOU START THIS PROCEEDURE. I hope that this information is helpful to you!!!.
Motorola... | Answered on Mar 15, 2019
You can try to clear the cache of the phone to see if these helps you. You can check the instructions trough the link: Clear Cache Partition on my device
Motorola... | Answered on Dec 07, 2016
Hi Devin,
In the link below you will find some steps so you can fix your phone. What should do if my DROID 4 freezes locks up displays blank or black...
Regards,
Maya
Motorola Support
Motorola... | Answered on Mar 25, 2016
Go to the "SETTINGS" app on your phone.
Toward the bottom of the "SETTINGS" menu you should see "ABOUT PHONE " or "SYSTEM UPDATE" (You may see both options). If you see the "SYSTEM UPDATE" option, tap on it, if an update is available for your phone, You will be given the appropriate options to download and install it.
If you do not see the "SYSTEM UPDATE" option, then tap on "ABOUT PHONE" then tap on "CHECK FOR SYSTEM UPDATES",
Motorola... | Answered on Jul 11, 2015
Long press volume down and power button..
Mark Motorola Support
Motorola... | Answered on Jul 07, 2015
Warren
You could call Verizon and ask. Some people use Check your ESN IMEI MEID free and instantly with Swappa to check for Clean ESN but it isn't guaranteed.
Mark
Motorola Support
You can try to reboot the device by pressing and holding the power key + volume down key for 10 seconds.
If it does not work, please try doing this
Clear Cache Partition on my device.
Regards.
Suny.
Motorola Support.
Motorola... | Answered on Apr 28, 2015
Try taking the battery out and replacing it back.
Motorola... | Answered on Mar 12, 2015
TRY WWW.FREEDOMPOP.COM I HAVE USED IT FOR OVER A YEAR NOW.
Motorola... | Answered on Jan 30, 2015
Dana
What device were you trying an object exchange with?
Mark
Motorola Support
Motorola... | Answered on Jan 22, 2015
Seth
Go to Motorola Support Find Answers Motorola Mobility Inc then find your device then search external reset.
Mark
Motorola Support
Robert
Contact Verizon for options.
Mark
Motorola Support
Brent
You'll need to do external factory data reset.
Mark
Motorola Support
You'll have to do external factory data reset.
Mark
Mark
Would like to help but need some more specifics on what is wrong with your Droid Turbo.
Mark
Motorola Support
Visit a Verizon store to have your phone evaluated.
Mark
Motorola Support
Motorola... | Answered on Jan 04, 2015
The best advice that I can give you is to actually DELETE the "Facebook" app from your phone. If You have the "Facebook" mobile app installed on your phone, here/s how to DELETE/REMOVE it.
1. Tap on APPS.
2. When you find SETTINGS Tap on SETTINGS (You are NOT looking for Google Settings, You are looking for the actual system settings which is labeled as SETTINGS in your APPS menu).
3. Tap SETTINGS
4. Scroll down until you see APPS
5. Tap on APPS.
6. Scroll through the list of apps until you find the Facebook Mobile App.
7. Tap on CLEAR CACHE
8. If there are options to CLEAR any other files then be sure to click on those options as well
9. FINALLY click UNINSTALL APP
10. When the app finishes the uninstall process RESTART YOUR PHONE.
NEXT TIME YOU GO THROUGH THE APPS THAT YOU HAVE INSTALLED ON YOUR PHONE, THE "FACEBOOK MOBILE APP" SHOULD NOT SHOW UP IN YOUR LIST OF APPS THAT YOU CURRENTLY HAVE INSTALLED ON YOUR PHONE.
Motorola... | Answered on Nov 24, 2014
Motorola Mobility Droid RAZR HD Logo
Popular Tags
157 questions posted
Top Motorola Mobility Cell Phones Experts
Lawrence Oravetz
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
RAZR Motorola Mobility
  • RAZR Motorola Mobility
Most Popular Question
get droid razr maxx hd updated
  • Cell Phones
