20 Most Recent
Power Center Jumpstart 11-411 Questions & Answers
My unit has been used
Take it apart. The battery inside has corroded the wires at the terminals. Replace ends clean and put protector spray on them.
Replacement cord for a jump box .
If you take the box apart - if you're able to easily remove the cable you want to replace - you can go to any automotive parts store and get a foot or two of the same gauge/color wire - and just remove your clamp and install on the new wire. Probably a 8 gauge or so - if you take the cable in and show them what you need they should be able to give you the pieces for less than $15 - you could also just buy a cheap set of jumper cables and use whichever lead you need - and you'd have 3 more leads to use down the road.
I need to buy a power cord for the 11-410
just make sure the specs for the replacement plug is correct:
AC ADAPTER
input: 110-115V 60Hz
output: 12V 500mA
pin size that plugs into the unit ~ 9mm or a bit tad over 3/16"
with that adaptor, it takes up to 36 hours to charge it up to FULL
with a comparable DC adapter, it takes only 8-10 hours
How to use a compact jump start system
The Jump Start replaces another vehicle when jump starting. Make sure unit is fully charged. If you need a jump start because of a dead battery in your car, connect Red lead to + battery post on your dead battery and Black lead form jump start to - battery post on dead battery. Turn unit on and start vehicle.
