20 Most Recent
Ingersoll Rand 1/2" Super Duty Air Impact Wrench Questions & Answers
Diagram of parts
you can download ingersoll rand tool manuals and parts lists fromwww.irtechpubs.com
Ingersoll rand 231A
if you have already used air tool oil you may have to take it apart and clean the motor vanes
No power at all
you should be able to order a rebuild kit thru the company that made or sold it
Runs untill you try to remove a bolt
I would check my reversal valve and make sure the knob is on the number 5 on both sides first and check my air inlet for trash. Other then that I would tear it down and inspect the tool for any broken parts or grooved front and rear plates in the air motor. If it all looks good I would order a tune up kit with bearings and replace everything that they give you in the kit. IR 231-TK3
Air leak on my IR231 A
It should just be the valve o-ring that is letting air bypass. Its located under your air inlet bushing. If you take out the bushing you will see a spring and a valve. The valve has a o-ring on it so just replace that and it should fix your problem.
Not enough power
check to see that the tool has 90 psi with trigger pulled, make sure the forward / reverse lever is aligned to hi.
Triger dont wokr
try lubricating it with air tool oil, put ten drops in at the air nipple, try tapping unit on table as you press trigger in and out.
LOW SUMP PRESSURE SHUT DOWN
more info would help but if it is shutting down because of "low oil" then you can do one of two things but first make sure the oil is at the proper level
unplug the low oil safety switch...
fix it correctly
next time, let us know what kind of engine you have and model numbers of everything involved
VSD Fault 23
Vsd 23 is a motor under speed problem. Check motor turnes ok, if not it could be a number if faults including the hall effect sensor that detect motor speed, you will need to call a Ingersoll Rand technicion in to do a 348 diagnostic test.
Start run capacitors wiring diagram for Ingersoll Rand T30 5HP
In a typical setup, start and run capacitors are not wired directly to each other. They serve different purposes in the motor circuit. Start capacitors are used to provide an extra boost of power to start the motor, while run capacitors help improve motor efficiency and performance during operation.
Here is a general wiring guideline for start and run capacitors:
- Start Capacitor: The start capacitor is usually connected in series with the motor's start winding. It helps provide an extra boost of power during motor startup. The wiring configuration typically involves connecting one lead of the start capacitor to the start winding, and the other lead to the common terminal or neutral connection.
- Run Capacitor: The run capacitor is typically connected in parallel with the motor's run winding. It helps improve motor efficiency and performance during operation. The wiring configuration usually involves connecting one lead of the run capacitor to the run winding, and the other lead to the common terminal or neutral connection.
It's important to consult the manufacturer's documentation, wiring diagram, or a qualified technician familiar with the specific model of your Ingersoll Rand T30 5HP compressor for the accurate wiring instructions. They will have the expertise to provide you with the precise wiring configuration and any specific considerations for your particular compressor model.
If you're unsure or uncomfortable with the wiring process, it's recommended to seek professional assistance from a qualified electrician or a technician experienced with motor wiring and compressor systems. They can ensure the wiring is done correctly and safely.
