20 Most Recent Amerec 4.5KW Heater w/ Built-in Dial Controls, 100-210 ACF Questions & Answers
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Amerec 4.5KW... | Answered on Sep 14, 2015
Please go through the entire MENU options to insure B&W option is not in Play and that COLOR is in play
Hardware &... | Answered on Dec 02, 2019
Your comments suggest your Noma timer could be defective.
Have someone explain the instructions to you.
Google (noma)(052-8815-049885)(manual) without parens OR contact Noma directly to request.
Hardware &... | Answered on Dec 01, 2019
Google (westinghouse)(28KC)(manual) without parens for instructions.
Hardware &... | Answered on Nov 30, 2019
Contact Aube directly to request.
Google (pagettraining)(9159)(manual) without parens.
Hardware &... | Answered on Nov 27, 2019
yes there is.
Utilitech 18 inch Hardwired Under Cabinet LED Light bar 38970-TI ...
https://www.ebay.com > ... > Wall Fixtures
See your home in the best possible light with the Utilitech 18 In. Direct Wire Light Fixture. This high powered, diffused LED light source is the ideal brightening ...
Hardware &... | Answered on Nov 26, 2019
USUALLY READING THE INSTRUCTIONS WORKS BEST . HAVE NEVER HAD ONE SO DID NOT NEED TO KNOW HOW
Hardware &... | Answered on Nov 25, 2019
Amerec 4.5KW Heater w/ Built-in Dial Controls, 100-210 ACF Logo
1 questions posted
Top Amerec Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you an Amerec Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Amerec Hardware & Accessories
Most Popular Question
sauna wont get hot enough
  • Hardware & Accessories
