20 Most Recent Electric Staple & Nail Gun Professional Grade Questions & Answers
2answers
Is it possible to shoot yourself in the chest?
I guess it would be depending on the type of tool. Most tools have a safety mechanism that would have to be defeated or completely disabled to fire without depressing the safety and could fire freely. I would think again depending on the product that there are guidelines on the proper use and safety of the tools and as far as anyone in the house there are not kid toys and I would not let a minor use one even under supervision unless the adult knows all the functions of the tool. You can go to Stanleybostitch.com and view some of their products and manuals. I hope I answered your question
10/22/2014 6:19:55 PM • Electric Staple... • Answered on Oct 22, 2014
Model #42131 battery powered electric stapler. Hums/ buzzing when started. Why? How to fix?
Hi, Please ensure that the batteries that you placed have enough energy to operate your stapler device. If you're unsure of the battery power level, you can buy new AA (ie double A) batteries from your local grocery store or gas station. And to be safe, I would also stick with the same brand of battery that initially came with the device. Otherwise, you can double check that the device has enough staples to operate properly. Thank you.
12/29/2022 2:35:50 AM • Electric Tools &... • Answered on Dec 29, 2022
Blue light on top of staple does not come on and the stapler does not work. Bostitch electric stapler model 02210
Hi, you might have a stapler jam. Please unplug your stapler and use a screw driver to clear out any staples in the stapling area. Then, you can pull out the stapler drawer and remove any jammed or stuck staplers. If this fails, please call Bostitch at 1 (800) 556-6696 if you don't have a manual to use to attempt next troubleshooting steps. Thank you.
10/10/2022 6:27:01 PM • Electric Tools &... • Answered on Oct 10, 2022
Master Mechanic model TRE-300 electric staple/brad gun. How can I load it?
https://www.google.com/search?q=Master+Mechanic+model+TRE-300+electric+staple%2Fbrad+gun&oq=Master+Mechanic+model+TRE-300+electric+staple%2Fbrad+gun&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
3/27/2021 1:11:51 AM • Electric Tools &... • Answered on Mar 27, 2021
How do I replace the spring on a Swingline electric staple gun model 34201
Unlikely you can. Contact them direct.
Contact Us ' Swingline
www.swingline.com > contact-us
Desktop Staplers · Electric Staplers · Heavy Duty & Specialty · Mini Staplers · Stapling Accessories · Punches · Manual Punches · Electric Punches · Heavy Duty ...
1/31/2021 9:11:48 PM • Electric Tools &... • Answered on Jan 31, 2021
I have a electric brad nail gun i bought at yard sale and it wont shoot the nail .whatcould i be doing wrong
YOU BOUGHT SOMWONWS JUNK FOR 5 BUCKS THROW IT BACK IN THE TRASH BIN
11/21/2020 12:00:34 PM • Electric Tools &... • Answered on Nov 21, 2020
Where can I get a collet for my tooltec 1020w electric router
Contact Tooltec directly to inquire.
10/30/2020 4:32:13 PM • Electric Tools &... • Answered on Oct 30, 2020
Manual for PowerShot item 9000 Electric Staple & Nail Gun Mfg by PowerShot Tool Co. Inc
Track Saw vs Circular Saw-which is best for your project March 19, 2020 By pervezWe use a saw for cutting wood or any material. In the market, we can find a lot of saws and it will do our desired work. If you are a woodcutter then a track saw will help you. A track saw is a handheld circular saw, on the other hand, a circular saw is one kind of power saw which helps to cut woods or any material.We can use track saw and circular saw for cutting woods and other materials like tile, brick. But there is a difference between them. We have to know what is Track Saw vs Circular Saw. see the difference between them given below. Track Saw vs Circular Saw Lets Have a quick look into these A user uses a saw for different cutting purposes circular saw and track saw is one of them. The track saw is used for cutting woods and circular saw also used for cutting woods too But both of them are used for different purposes.
Circular Saw
We use a circular saw for cutting woods and it uses a round blade lined sharp metal blade. A circular saw is used for cutting woods, plastic, metal, and masonry. Circular saw is an electrical saw and it runs through electricity. There are some things in a circular saw and they are-
  • An on/off switch
  • A handle and upper guard
  • A cutting blade and lower blade guard
Safety Procedure Circular saw is a powerful tool and it is dangerous too. A user must wear safety equipment while using this circular saw. Moreover, this tool can produce a lot of dust so better is use masks for it. We have to hold the saw perfectly with both hands so that it will not move from the place. If you have enough time then you may go through the article- Top Circular saw Buying Guide.
Track Saw
The track saw is a handheld circular saw and this helps a user to cut logs accurately. A track saw can cut any log faster than a circular saw because they are lightweight and portable. The layer on a track saw creates an effective dust trap and also doesn't just enclose the blade. The track saw is suitable in any situation because of its rubber strips at the bottom. It is easy to cut and no need for measurement and it can make a big cut into small pieces. The Benefit of Track Saw
  • A track saw is easy to move
  • Smooth and clean cuts
  • Long meters for cutting any objects
Mainly a track is easy to move from one place to another place and it will give a user smooth and clean cuts than other saws in the market. Easy to cut no measurement needs to cut a log or any material just line it up and cut it. No guesswork or measurement is needed to cut woods. Should a User Choose a Track or Circular Saw? A track saw and circular saw both of them these are using for cutting any material or woods or a tile or metal and plastic things. The track saw is one kind of circular saw which is portable and easy to use than a circular saw. A circular saw is a powerful and electrical saw. The user has to be careful while using this saw because any single mistake can risk his life. So if a user loves to use a handheld saw then he should go for a track saw and if he wants a powerful saw then he should go for a circular saw.
Circular Vs TrackSaw
Track saw and circular saw both of them use a circular blade but track saw blades are less uncover. The major and main difference between them is one is easy to move another is complex to move. Another difference is track saw provides a better cut and smooth performance than a circular saw. Circular saw creates more dust than a track saw because in a track saw a dust filter contain on it(track saw). The circular saw is best for construction purposes because it can give you the best performance than a track saw. If you are going to cut lumber or a tree on a roof than a circular saw can help you better than a track saw. So better is if a user wants to use a portable lightweight saw than track saw is better for him. But if he wants to use a saw that provides more facility than circular saw is for him. Final Words Both of this saw is perfect for cutting wood or any kind of material. A track saw is portable and lightweight on the other hand a circular saw is more powerful than any other saw. You can carry a track saw with you in your shoulder but can't carry a circular saw with you. So if you want a lightweight saw then track is for you or if you want a powerful saw then circular saw is for you. Filed Under: Guide
3/28/2020 6:49:20 PM • Electric Tools &... • Answered on Mar 28, 2020
Where can i buy nails for my swingline electric nailgun #32001
Amazon.com
10/3/2019 9:07:10 PM • Electric Tools &... • Answered on Oct 03, 2019
Bostitch electric stapler 02011. Clicks like it is stapling but no staple comes out. The only way I can is by opening and shutting each time..And it is brand new. Worked the first week only
If it is brand new take it and your receipt back to the store where you purchased it and get a replacement.
9/27/2019 1:11:10 AM • Electric Tools &... • Answered on Sep 27, 2019
Where do I buy 15mms nails for the fasteners 2in1 electric stapler nailer
any hardware store
6/30/2019 9:01:59 PM • Electric Tools &... • Answered on Jun 30, 2019
Parker tre50 electric stapler won't shoot
unplug it and flip it over and see if there is something jammed if not, then when its still upside down, and unplugged find something flat and stiff about the width of the blade of the stapler. slide it up and make sure the driver blade is returning. if it doesn't go up the staples cannot feed and while it will fire it wont be on top of the staple when it fires.
3/22/2019 9:38:12 PM • Electric Tools &... • Answered on Mar 22, 2019
Need a Manuel for a power fist 7 amp electric plunge router.(8120073) Cannot get bits to stay in
Try wet site. -Make sure the collar still can be tight in order to hole the router bit in place. -If not then just replace new collar kit. You should be good to go for any project. Good luck Mai
6/14/2018 6:11:14 PM • Electric Tools &... • Answered on Jun 14, 2018
Electric Staple & Nail Gun Professional Grade Logo
3 questions posted
Top Electric Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Electric Tools & Hardware - Others
Most Popular Question
possible shoot yourself in chest
  • Tools & Hardware - Others
