20 Most Recent Speed Leviton Vizia VZM06-1LZ, 600W, 120 VAC Magnetic Low-Voltage Dimmer with 3 C Questions & Answers
DOES THIS DIMMER WORK WITH LED LIGHT BULB
It's not quite that simple.. According to the manual for your switch, it is stated "Use with magnetic low-voltage transformers, incandescent, or 120V halogen fixtures only." Also, there is a minimum load of 40W or 40VA. Your LED lamp load will need to satisfy BOTH of these requirements. Electronic circuits are not to be "dimmed" with this dimmer - but use of either the VZE04-1L (400W max) or VZE06-1L (600W max) is supported.You will need to provide the manufacturer and model number of the LED lamp(s) to be dimmed by this switch. Or, you can use traditional dimmers (if desired) with LED lamps that are specifically labeled as "dimmable" on their packaging. Once the lamp model is known it will be possible to learn about their dimability assuming that they are not cheap imports with no real customer support contacts. Name brand lamps will have this support, and you can even call them yourself and inquire directly about the suitability to task for the dimmer. If the lam company doesn't know about the switch, contact Leviton with the lamp info at Customer Service: 1-800-323-8920 • FAX: 1-800-832-9538 Tech Line: 1-800-824-3005 Good luck!
5/14/2012 8:22:18 PM • Speed Leviton... • Answered on May 14, 2012
Predator generator 4000 problems idle speed up and down
Engine surge/governor hunting are usually a carburetor issue. First check air filter, drain fuel tank, drain and clean carburetor fuel bowl. Then use fresh fuel from a clean dry fuel can. If its still hunting, check that the carburetor mounting bolts are not loose. If carburetor mount is good, then the carburetor likely needs cleaning or replaced. You could also try SeaFoam or other similar fuel treatment. Just follow label directions, usually 1 oz / gal... measure don't guess.
1/18/2019 1:42:35 PM • Speed Electrical... • Answered on Jan 18, 2019
3answers
A diesel engin uses diesel fuel generates low power at low speed
Increase the speed for constand power output, or check the load it maybe more than the genset can power.
9/11/2018 6:59:51 AM • Speed Electrical... • Answered on Sep 11, 2018
2answers
Generator starts before it gets upto speed the frequency and voltage lights flash and the generator shuts down within 30 seconds from start. What is the problem?
Mybe power from the commercial supply had failed . Or power surge occured and the genset detected power failure. The other cause could be air bubbles in the gasoline.The genset may need bleeding to remove air bubbles in the gasoline.
9/1/2018 6:57:29 AM • Speed Electrical... • Answered on Sep 01, 2018
Where can I buy replacement knobs for dual slider dimmer and fan speed switch? Mine cracked and fell off
Sorry but we do not have a parts locator service at this website.
10/6/2017 7:34:27 PM • Speed Electrical... • Answered on Oct 06, 2017
My generator isnt kicking down when its supposed too, it runs at continuous speed
An AC generating set runs at a continuous speed in order to produce current at the correct Hz - 60Hz in the USA and 50Hz almost everywhere else. The built-in governor will maintain the preset speed, opening and closing the throttle automatically as a load is plugged in or removed.
4/6/2017 1:02:26 AM • Speed Electrical... • Answered on Apr 06, 2017
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
Speed Leviton Vizia VZM06-1LZ, 600W, 120 VAC Magnetic Low-Voltage Dimmer with 3 C Logo
2 questions posted
Top Speed Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Speed Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Speed Electrical Supplies
Most Popular Question
dimmer work led light bulb
  • Electrical Supplies
