20 Most Recent Samsung AW1893L Air Conditioner Questions & Answers
I have 2 Samsung AW0700/XAA
inside the unit on the left side of the evaporator coil there should be a channel that allows the water to drain to the outside of the unit and cool the condenser coil use compressed air to clean this channel (a.k.a. keyboard cleaner) were safty glasses and make sure unit is unplugged then check drain to make sure it is clear before running the unit.
7/24/2011 11:09:26 AM • Samsung AW1893L... • Answered on Jul 24, 2011
tip
Good day,<br /><br />If you have the above mentioned air conditioner and you are having problems with it please follow the provided link to download the service manual.<br /><br />With the service manual you will be able to find common problems and solutions to that problems. All you have to do is follow the link and download the manual.<br /><br /><a href="http://appliancedigest.com/index.php?/files/file/526-sam0004-samsung-room-air-conditioner-service-manual/">Link to download the manual</a><br /><br />I sincerely hope that by posting the link to the manual it will be helpful in some way or another.<br /><br />Have a wonderful day!<br /><br />Kind regards<br /><br />
Taking load
Hello my name is Heath it will be my pleasure to assist you. Alot of times the coil gets plugged and then it makes the fan and compressor work harder so a good coil cleaning should get the amps on the unit to come down.
4/22/2010 12:33:22 PM • Samsung AW1893L... • Answered on Apr 22, 2010
I want to get services of my ac which is i
Fixya - We Do not Represent Samsung. It is a Group of Individuals from Different Fields who would help you to Fix anything from AC to Notebook.
As far your Question is Concerned,it is FREE for the First Year. The Service Center Number for Samsung :-
: 3030 8282*, 1800 110011**, 1800 3000 8282, 18002668282Monday – Sunday : 9.00 AM - 8.00 PM(IST)Make sure, They would ask a Copy of the Purchase Receipt.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
3/2/2010 11:01:37 AM • Samsung AW1893L... • Answered on Mar 02, 2010
2answers
Blowin warm air, filter cleaned
The compressor may not be coming on,see if it is humming,and if it is,the compressor maybe bad,or out of freon.If it is not running(compressor)then the thermostat maybe bad.
11/14/2009 12:12:26 AM • Samsung AW1893L... • Answered on Nov 14, 2009
2answers
Need installation info
tilt the unit toward the back so it will drain toward the back or you will have a mess on your hands,tilt it just about 1/2 in so the water runs toward the back and drains outside and very important to air filter clean
8/20/2009 1:00:49 PM • Samsung AW1893L... • Answered on Aug 20, 2009
What coul b the problem
If it is not coming on at all, check the breakers and power supply first, if it has power then the probelm could be in the controls. If the breaker or fuse is tripped/blown and will not reset or hold the fuse then you have problems with one of the components in the system
7/27/2009 3:16:25 AM • Samsung AW1893L... • Answered on Jul 27, 2009
Ac is not giving sfficient cool air,,, help
your ac is probably low on freon or your filter and evaportator coil are dirty
6/26/2009 10:55:07 PM • Samsung AW1893L... • Answered on Jun 26, 2009
Need Help with Airconditioner
no promlem ur welcome
6/27/2008 12:01:49 AM • Samsung AW1893L... • Answered on Jun 27, 2008
Air conditioner not getting cold
low on freon by the time u pay someone to repair it u could buy a new one
6/20/2008 2:08:46 AM • Samsung AW1893L... • Answered on Jun 20, 2008
2answers
How to turn on beep in samsung AC remote??
Press 2nd f button and then beep off button
3/31/2024 2:43:24 PM • Samsung Heating... • Answered on Mar 31, 2024
Samsung VRF System. One of the indoor unit of it is not working. What error code will it display?
I answered this earlier and still no model number.
Samsung DVM S Error Code Booklet
GT Phelan https://gtphelan.ie > uploads > 2019/07 > DVM-... PDF Welcome to the new Samsung Error Code Booklet, for our repair network. This booklet has been designed to offer on site assistance for fault code. 39 pages
Samsung VRF Air Conditioner Fault Codes
samsungvrf.com.tr https://www.samsungvrf.com.tr > samsung-vrf-klima-a... Samsung VRF Service Fault Codes and Solutions ; 147, Closed EVA2_in Sensor Break Away Error ; 148, Closed EVA2_OUT Sensor Break Away Error ; 149, AHU Master Indoor ... ..
2/15/2024 3:11:52 AM • Samsung Heating... • Answered on Feb 15, 2024
What does the code E4 mean on my Samsung range
These are error code list of samsung range Samsung range or wall oven error codes
12/15/2023 1:40:02 PM • Samsung Heating... • Answered on Dec 15, 2023
Samsung digital inverter ac c1 error code
The C1 error code on a Samsung digital inverter AC usually indicates a communication error between the indoor and outdoor units. This could be caused by a faulty control board or a wiring issue. To troubleshoot this issue, you can try resetting the unit by turning off the power supply for a few minutes and then turning it back on. If the error persists, you may need to call a professional technician to diagnose and fix the issue. They may need to check the wiring connections and replace any faulty parts if necessary.
2/26/2023 2:46:35 PM • Samsung Heating... • Answered on Feb 26, 2023
2answers
How to sovle the error code e206 for samsung air conditioner?
What is the M# S# of unit?
2/24/2023 8:26:55 AM • Samsung Heating... • Answered on Feb 24, 2023
Hauzen air conditioner remote instructions
I cannot read my remote for my air conditioner due to it being in Korean. Is there any way that I can get the instructions in English?
12/1/2022 11:49:21 AM • Samsung Heating... • Answered on Dec 01, 2022
Samsung AW1893L Air Conditioner Logo
Popular Tags
22 questions posted
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Heating & Cooling
Most Popular Question
2 samsung aw0700 xaa
  • Heating & Cooling
