20 Most Recent Samsung Phone PDCSLCD12B Questions & Answers
HOW DO I RE PROGRAM A MEMORY BUTTON TO ANOTHER NUMBER
On the Samsung Prostar there are programmable buttons, which is what I think that you are referring to, in your case a Samsung Prostar 12btn handset. The easiest way for me to show explain how to do this on the Samsung Prostar is by watching the video which I have uploaded for you. if you prefer written instruction please log on to www,abbeytelecom.com
1/10/2019 6:50:41 AM • Samsung Phone... • Answered on Jan 10, 2019
2answers
Samsung DCS Compact: How to connect MOH
Hi Dave,
Sorry I've been out of town and I'm just catching up. I looked at the info I sent to you and eventhough it is under the heading of Compact I think it is for a Prostar. The info is under the DCS heading and is called " DCS Technical Manual August 1995" Pages 186, 187, 197 and 200. I have not given up and I'm looking through my other reference materials but you are right, there are a lot of user and programming guides but no installation guides. I'll keep trying, so do not give up. "Talk" to you soon ....Mitelmike
3/17/2014 6:04:08 PM • Samsung Phone... • Answered on Mar 17, 2014
How do I program buttons
Hi I have posted a video off http://www.abbeytelecom.com showing how to do the soft key programming, a tip is when programming the transfer to voicemail - it shows as VT *** ( voicemail group number).
5/2/2013 9:12:47 PM • Samsung Phone... • Answered on May 02, 2013
Old Unknown Password for Voicemail
Unfortunately the passwords can not be seen and the only solution is to delete the mailbox and re-install it. Your Admin Assistant should be able to add and delete mailboxes. Sorry, Let me know if you need help with deleting and adding the mailbox. .....Mitelmike
3/12/2012 8:20:53 PM • Samsung Phone... • Answered on Mar 12, 2012
Empty Message
Follow these steps and this should fix the problem.
on the phone that shows this msg.
Without picking up the handset .
press the transfer btn
dial 115
dial 00
press transfer.
10/19/2011 8:37:38 PM • Samsung Phone... • Answered on Oct 19, 2011
How can I get the
firstly do you have inbound CLI coming into the building?, if not you simply need to ask your line provider to switch this feature on. If it is already on but not showing at this handset ; with the handset down ;
dial transfer
200
1234
1 to enable then the speaker (blue) key
then press 312
type in your extension number and use the 3rd button under the screen and the volume key to set to allow yes.
for other programming tips go to www.abbeytelecom.com I have posted the 'date and time' video, as you will also need this very soon, regards
9/22/2011 1:08:31 PM • Samsung Phone... • Answered on Sep 22, 2011
0answers
Our Samsung dcs 12b phone won't let us dial in
Hi, have you checked that you have enough channels (lines) available, and I know it sounds obvious but have you dialled 9? I've put a Video on explaining Conference - it is off http://www.abbeytelecom.com this might help I hope.
6/20/2011 10:04:54 AM • Samsung Phone... • Answered on Jun 20, 2011
How diow you change time
Watch this clip for changing the time on Samsung phone systems. More at www.AbbeyTelecom.com
3/26/2011 9:03:55 AM • Samsung Phone... • Answered on Mar 26, 2011
How do i get caller display
Hi, you need to ask your line provider if this is being sent to you, if it is and it is just a case of not being able to read the information at that handset on screen then you need to press;
Transfer 200
passcode 1234
1 to enable
Speaker key
Then go to 323. type in the extension numbers you want to show this info and press RECIEVE CLI:YES .
If your line provider is not sending this then you can ask them to start sending CLi, it is chargable but not too much.
I hope that this helps, there are over 60 Samsung telecoms training videos at http://www.abbeytelecom.com which might help too, I've posted a link for the date/time which is due to change this weekend
TRANSFER 119 use your volume key until it reads 'CLI NAME FIRST'
3/16/2011 12:40:58 PM • Samsung Phone... • Answered on Mar 16, 2011
How do you allocate an
Hi to program your soft keys either follow the instruction or click on the link that I have posted, the video shows the newer handsets but these are very similar to your 12 button handset, ther are 60+ training clips at http://abbeytelecom.com
Press the transfer button followed by 200
Enter 1234
Press 1 to 'ENABLE'
Press the speaker key
Now press 722 followed by the extension number of the handset.
Type in the number of the button you wish to change.
If it is button 3 then type 03, if it is button 11 type 11 etc.
Once you have done this the cursor will move to the right hand side of the screen.
Next press the letter D on the keypad followed by plus on the volume until it says DS.
When it says DS press the 3rd grey key beneath the screen followed by the extension number. EG DS255.
Once you have done this press the 3rd grey key beneath the screen to save.
3/16/2011 12:23:00 PM • Samsung Phone... • Answered on Mar 16, 2011
Cannot set the time and
HI, i got the scoop on how to change the date and time. first while handset is on hook press TRSF then dial 200 Dial 1234 the display shows enable cus prog dial 1 to enable then press TRSF To change the date and time from here out press TRSF and dial 505 the display will show : (this is an example)
old: 6010104:0047
new:WMMDDYY:HHMM
Enter the new time and date using the above format and the system will return to step 2. Verify the time and date and re enter if necessary Press TRSF to store and exit. or press SPK to store and advance to the next program.
Hope it helped....
Good luck..
3/15/2011 1:25:31 AM • Samsung Phone... • Answered on Mar 15, 2011
Our office has Samsung KPDCS-12B
to program the directory on a 12 button handse;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
Your next command will be the MMC required.
To program the system speed dial directory
Enter 705 - Speed dial 12th Button down to toggle between
Enter 706 - Speed Name the 2 MMC
3/7/2011 2:11:02 PM • Samsung Phone... • Answered on Mar 07, 2011
Lands Phones Logo
81 questions posted
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Lands Phones
Most Popular Question
re program memory button another number
  • Lands Phones
