20 Most Recent Miller Electric Manufacturing Electric Syncrowave 250 DX TIG 907194032 Welder Questions & Answers
3answers
Welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
4/28/2020 6:37:39 AM • Miller Electric... • Answered on Apr 28, 2020
I have a miller sycrowave 250DX i have been tig
Did the machine ever work properly? I am assuming you are using a remote for tig welding. If you watch the points, does the HF stay on after the 5 to 10 seconds as you stated. It should stay on as long as you activate the machine. Make sure your Start Mode is in continuous. See page 42. Since there are so many options, check page 34 for help setting the options. If you still cannot get ti to weld properly, contact Miller for service. https://www.millerwelds.com/files/owners-manuals/O363AU_MIL.pdf
11/6/2017 12:52:00 AM • Miller Electric... • Answered on Nov 06, 2017
I have a syncrowave 250, it is about 12 years old.
Jon, I would like to suggest to you that you post this question on the millerwelds forum. There are some very experienced tech guys there that can help you much better. Go to millerwelds.com and select the forums under the resources tab. You will be surprised. Hope you can get it running again. Ryan
4/21/2017 7:18:00 PM • Miller Electric... • Answered on Apr 21, 2017
0answers
2answers
Cannot get syncrowave to weld aluminum
must use remote output for tig
4/2/2014 7:48:54 AM • Miller Electric... • Answered on Apr 02, 2014
Can't set up syncrowave 351 to tig weld
Set the "arc balance" control between 40-50, also. You need to be up around 200-220 amps too. Make sure you're using 3/32 tungsten (green, red) and running about 25-30 cfh on your argon. Ball that end on the tungsten.
5/5/2013 2:01:46 PM • Miller Electric... • Answered on May 05, 2013
2answers
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
6/1/2012 3:45:12 AM • Miller Electric... • Answered on Jun 01, 2012
I need a electrical wiring diagram, for syncrowave
Hi:Here's the link to the owners manual. Check page 18 for the right voltage using the jumper links.http://www.millerwelds.com/om/o353u_mil.pdfRegards,
9/27/2011 4:55:08 PM • Miller Electric... • Answered on Sep 27, 2011
Gas keeps running after you
Hi:
The normal set up on the 250 syncrowave will allow you to control your pre and post flow of gas. If the post flow is set up to more than 2 seconds that's the problem. If it is set on zero, then you have a leaky solenoid valve. Check your owners manual for troubleshooting anf repair.
8/3/2011 5:38:59 AM • Miller Electric... • Answered on Aug 03, 2011
2answers
Syncrowave 250 dx aluminum set up
You can go to millerwelds.com and download the manual for this machine..it should help you
8/19/2010 5:27:01 PM • Miller Electric... • Answered on Aug 19, 2010
Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
7/24/2010 5:10:01 AM • Miller Electric... • Answered on Jul 24, 2010
Looking for plastic housing
Check with www.millerwelds.com they should be the ones who can help you.
3/30/2010 8:15:46 AM • Miller Electric... • Answered on Mar 30, 2010
Miller Electric Manufacturing  Electric Syncrowave  250 DX TIG 907194032 Welder Logo
Popular Tags
28 questions posted
Top Miller Welding Tools Experts
Sean Wright
Sean Wright
john h
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Miller Welding Tools
Most Popular Question
39 t set up syncrowave 351 tig weld
  • Welding Tools
