20 Most Recent
Nintendo Donkey Kong Country 2: Diddy's Kong Quest for Super Questions & Answers
How do i save a game on Super NES
Kong Kollege. You talk to the Grandma Kong and she'll let you save your game. Available after the second level on the first map.
Had to go back and play the game, I couldn't remember what it was!!!
Now I have to play it more! Darn you!
-Kaptain Jake :P
I have a blinking red light on my nintendo nes game system. what does that mean?
The blinking red light on your Nintendo NES game system typically indicates a connection or cartridge issue. It could mean that the cartridge isn't inserted properly or is dirty. Try removing the cartridge, blowing on it to remove dust, and reinserting it firmly. If the problem persists, you may want to clean the connectors on both the cartridge and the NES system with a soft, clean cloth or cleaning solution specifically designed for this purpose. If that doesn't resolve the issue, there might be a more serious problem with the console, and you may need to consult a technician for repairs.
Red light and clicking sound Nintendo wii
It could very well be the fact that it has stopped working and has now died on you guys also. You can be another Wii console from Lukie Games or DKOldies or JJ games or East Starland games.
Wii U power saver screen?
I think that the Wi U console that you have bought is broken and you will have to bu another Wii U console. Lukie Games and DK Oldies and East Starland Games and JJ games sells Wii U consoles.
Trying to connect to wifi
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from:
What to do:
If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
- Errors ending in 0 = connection file 1
- Errors ending in 1 = connection file 2
- Errors ending in 2 = connection file 3
- Errors ending in 3 = Nintendo Wi-Fi USB Connector
- Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
- America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
- If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector,
click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please
click here for more information.
Connecting from a non-partnered Hotspot:
- The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
- If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
- Try another Hotspot. To search for known Hotspots in your area, click here.
How come my Nintendo game boy advance is not turning on with brand new batteries installed?
It could be that the power switch went bad is is not working or the fuses has quit working and need to be replaced or a loose connection with the screen then for your gameboy advance to not be powering on. Or the battery terminals are loose or broken and need to be replaced.It may of just had died t on you if it is very old. You should purchase a new gameboy advance then from Lukie games and East Starland games and DKOldies.
Error code 51030 for wii console
Error number 51030 mean that there is no wireless network that is within a range of your WII console is either configured into it or is compatible with it and your WII console will try to do anything that does requires an internet connection. This could mean that the password could of have been changed or was configured incorrectly on the console.
Why is it that the battery life seems to be shorter for my Nintendo game boy advance SP hand held console?
I am guessing that the battery needs to be replaced in your gameboy advance SP and after 500 charges the battery will only be 70% working and temperature can also effect the battery too. If the light is flickering green and red at the same time that is also an indicator that the battery is going bad and has to be replaced.DkOldies and Lukie Games and East Starland games sell replacement batteries for gameboy advance SP's.
