20 Most Recent Samsung SMH7174BC Microwave Oven Questions & Answers
Samsung e42 microwave oven
See these results.
4/6/2018 3:05:16 PM • Samsung... • Answered on Apr 06, 2018
Upon setting the unit up--mod#smh7174wc--it will start up but quit after only3,4,5 seconds as if a breaker kicked out--no breaker external to unit kicks out--confirmed with using ext cord to plug into
It sounds like you may have one or more bad connections on the bottom of your noise filter board. The service manual for your model is here. You or a friend can check the connections for "ring cracks," and if any are present, remove the old solder and apply fresh 60/40 tin/lead solder. If the push-on terminals are damaged, they must be replaced, too. More questions? Contact me directly here.* * always include the full model number and FCC ID number from the label on / in your microwave smh9187st_noise_filter_board_connections2_small-l1w2uc1mgnmdxwxqhwe3r0vy-2-0.jpg connector_warnings_all-l1w2uc1mgnmdxwxqhwe3r0vy-2-3.jpg ring_crack-l1w2uc1mgnmdxwxqhwe3r0vy-2-10.jpg
1/28/2018 9:43:29 PM • Samsung... • Answered on Jan 28, 2018
3answers
Samsung Microwave runs won't heat
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
1/10/2018 11:23:46 PM • Samsung... • Answered on Jan 10, 2018
Samsung overcounter microwave-light and fan problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
8/14/2014 5:41:27 PM • Samsung... • Answered on Aug 14, 2014
Replacing outer cover on over the range Samsung Microwave
With the full model number, we could have linked you to the service manual.You can find helpful exploded view diagrams and order parts by entering your full model number here.
9/24/2013 12:09:42 PM • Samsung... • Answered on Sep 24, 2013
0answers
Model MR5492
Be the first to answer 8/23/2013 3:17:13 PM • Samsung... • Posted on Aug 23, 2013Be the first to answer
Samsung microwave oven is dead,
0.03 ohms? Should read 'short' if it (the fuses) are good. Does your Volt Ohm Meter have a position that beeps if it reads a short? (touch one probe to the other to produce a short and observe the reading) You should get the same reading on a good fuse ... beep or reading. Is your microwave 220 volts?
There is not much that goes wrong with a microwave,really. You are on the right track. Test the fuses. If you get power but no heat, I recommend you suspect (and inspect) the door safety interlock micro switches. If these switches fail, the oven doesnt know if the door is open or closed.
Let me know what you find out please ...
Thanks for your interest in FixYa.com
7/17/2011 9:54:48 PM • Samsung... • Answered on Jul 17, 2011
Our microwave has an error code -SE- and will not
Hi wmp_44,
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
6/8/2011 3:42:46 AM • Samsung... • Answered on Jun 08, 2011
0answers
Samsung Model number MS 103HCE
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/,..
3/27/2011 6:11:13 PM • Samsung... • Answered on Mar 27, 2011
Samsung microwave model smh7178ste runs, but does
Hello & Welcome to FixYa
E-63 error code in your Samsung Microwave is a T1 maximum timer error which means that the power control board has gone bad and needs replacement. However, before replacing it you can unplug the unit for 5-10 minutes to do a hard reset, if the problem is back then replacing the PCB is recommended repair. Please get back to me if you have any other questions.
Kevin
3/15/2011 8:09:11 PM • Samsung... • Answered on Mar 15, 2011
Microwave Ovens Logo
71 questions posted
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
samsung mw 87l microwave just suddenly
  • Microwave Ovens
