20 Most Recent Gestetner DSc332 Copier Questions & Answers
Tech imagerunner
Hi, I will solve your problem i just require a little bit of extra information. 1:Your current OS(operating system for example win xp,vista,7 of 8) 2:Your System type.(easy way to find it is press 'Ctrl+Alt+Del' go to task manager, at the left top on the menus at File>New Task(run) write cmd click OK or press ENTER then your cmd will apear just write wmic os get osarchitecture. The results can only be 32bit, 64bit(32bit can also be 86bit)). 3:More or less what you changed only if possible. My email : [email protected]. I will send you step by step instructions how to fix your problem.Im hoping to hear from you. Please rate me. Thanks
11/22/2013 7:23:26 PM • Gestetner DSc332... • Answered on Nov 22, 2013
0answers
Hello I have 232 Aficio copier.I have error SC
SC221: Scan Length Error Detection". For further help regarding this problem,refer to http://www.copytechnet.com/forums/ricoh-savin-gestetner/42342-mp5000b-sc-221-a.html
10/12/2011 6:08:37 PM • Gestetner DSc332... • Answered on Oct 12, 2011
I was wanting to know
yes you can copy on transparence via stock by pass, set the bypass to special paper, transparency/OHP, size of transparency ex. A4
9/3/2011 6:29:45 AM • Gestetner DSc332... • Answered on Sep 03, 2011
We have been advised to
in our country we use 70g or 80 this paper good not bad some people work on 60g but it stacking on machine good luck
7/13/2011 3:13:42 PM • Gestetner DSc332... • Answered on Jul 13, 2011
My Gestetner DSC332 SC630 error
It never finish warming up.In the copier there is a fuser unit.This fuser unit gets warmed up.After the fuser gets warmed up, the internal heat temperature gets set.But in your case, the fuse is not getting warmed till its required temperature, so it just gives the warm up message and it just remains there.Most probably its weak fuser assembly issue .Either getting the fuser assembly cleaned will help other wise the fuser has to be replaced, if cleaning the fuser is not helping.The fuse means , internal heating electrode. But also check and confirm, that there is no paper jam, unplug the copier power cord from wall outlet and check for internal paper jam.Remove the drum unit out and refit, then again connect the power cord and turn it on and check.If that is not helping and there is no paper jam issue, then its the fuser related problem.You will have to get the fuse checked.---------- This will help.Thanks.Helpmech.
4/23/2011 9:21:16 PM • Gestetner DSc332... • Answered on Apr 23, 2011
Error sc:320
polygon mirror gone its inside the lazer unit (if it is a digital copier) if thats the case ull need a new 1 about £60 from ricoh uk
11/4/2010 10:21:30 PM • Gestetner DSc332... • Answered on Nov 04, 2010
Getting error custome settings unavailable
login as admin(pc), and add accessories
5/8/2009 5:13:03 AM • Gestetner DSc332... • Answered on May 08, 2009
Ricoh 1022 - Error SC320
USE A BIG PHILIP SCREW AND REMOVE THE 2 PCS SCREW IN LEFT SIDE AND REMOVE THE COVER WHERE THE PAPER IS EXIT. YOU SEE A BLACK BOX INSIDE, AND USE A SMALL PHILIP SCREW TO REMOVE THE 4 PCS SCREW LOCATED IN HOLE. THEN LIFT UP THE BLACK BOX AND OPEN IT. BE CAREFULL
2/10/2009 9:30:44 PM • Gestetner DSc332... • Answered on Feb 10, 2009
Had a paper jam. Cleared the jam.
you have go to SP mode to reset it;
1, power on,
2, press "clear mode" enter107 and "clear/stop" for few second
3, press "copier SP mode
4, turn power off (5 second) and back on.
12/15/2008 1:56:03 AM • Gestetner DSc332... • Answered on Dec 15, 2008
Gestetner DSC332 SC393-02
Hello klwhite,
The answer to your question:
Savin.......3224/3828/2820
Ricoh......2232c/2238c/2228c
The error code means that there is a problem with the yellow dev unit. The manual says that "during warm up" the TD sensor saw .78 volts or less when it performed process control. We both know that this device may perform process control at times other than warm up. Sounds like the yellow dev unit is the problem as the sc393 means td sensor and the 02 means yellow developer unit. I truly hope I have helped you. Take care.........spinal......
8/20/2008 5:29:42 PM • Gestetner DSc332... • Answered on Aug 20, 2008
GESTETNER DSc323 - SUPER G3
If you look at the paper exit you will see 4 white exit wheels
in the middle of the 2 center ones you will see that there is a black
lever. This needs to be pushed back into position so that it is horizontal to the exit wheels.
Hope this helps regards
Myott
6/1/2008 12:08:17 PM • Gestetner DSc332... • Answered on Jun 01, 2008
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
11/29/2007 7:43:33 PM • Gestetner DSc332... • Answered on Nov 29, 2007
2answers
Ihave Gestetner 5327 an having
Check out the website www.arico1.com. They do repair on duplicator machine drums.
10/10/2021 2:53:28 PM • Gestetner Office... • Answered on Oct 10, 2021
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
1/15/2021 4:04:21 AM • Gestetner Office... • Answered on Jan 15, 2021
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website. This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this; Open the right side cover, unlatch all the bits at that side. Open the straight pass door on the left side. remove ALL the paper drawers. Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message. If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
1/14/2021 4:54:33 PM • Gestetner Office... • Answered on Jan 14, 2021
Gestetner DX2430 error code E-00
Clamper error The MPU cannot detect the clamper position sensor signal ( open or closed) within 3.0 seconds after the clamper
12/2/2019 1:38:38 PM • Gestetner Office... • Answered on Dec 02, 2019
26 questions posted
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
gestetner dsc332 sc393 02
  • Office Equipment & Supplies
