20 Most Recent Ubi Soft Chessmaster 10th Edition Questions & Answers
0answers
Black screen
Be the first to answer 5/17/2015 1:48:44 PM • Ubi Soft... • Posted on May 17, 2015Be the first to answer
0answers
Chessmaster
Be the first to answer 1/8/2014 3:16:07 AM • Ubi Soft... • Posted on Jan 08, 2014Be the first to answer
Everytime i try to play
Try Hardware Acceleration Option. .Go to control panel,display,settings tab,advanced,troubleshoot tab,move slider to Full.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/22/2012 5:30:30 AM • Ubi Soft... • Answered on Jan 22, 2012
Chessmaster 10th error message
you need a graphics card more than 128 mb to run
1/22/2012 5:18:20 AM • Ubi Soft... • Answered on Jan 22, 2012
3answers
Cannot initialize 3D engine
the problem on the Chessmaster 10th Cannot initialize 3D engine is that the game support only 1024x768 on screen resolution. Do that and works fine. Peace for all.
6/2/2011 10:15:16 PM • Ubi Soft... • Answered on Jun 02, 2011
I get an error 1606
Hello there,
Error 1606 is a windows Error here is the link to help you fix the problem
http://support.microsoft.com/kb/315352
To resolve this behavior, follow these steps.
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. Locate and then click the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  4. In the right pane of Registry Editor, double-click Common Administrative Tools.
  5. In the Value data box , type the following line, and then click OK: %ALLUSERSPROFILE%\Start Menu\Programs\Administrative Tools
  6. On the File menu, click Exit to quit Registry Editor.
  7. Restart the computer.
Thank you don't forget to Rate
1/25/2011 10:47:47 PM • Ubi Soft... • Answered on Jan 25, 2011
"Failed to attach personality"
When I start Chessmaster, and click on Play-Trining Mode, it says "failed to attach personalities", and I can't play chess
1/21/2011 6:40:15 PM • Ubi Soft... • Answered on Jan 21, 2011
Hi, my chessmaster 10 edition
actual your wrong on all acounts... your chessmaster should run just fine on your version of windows.. it sounds like it glitching because of you computer itself.. now chess doesnt sound like a game that needs alot of graphics to play but the graphics card can be one.. i would suggest checking your core temp (cpu fan) in your bios (look it up buddy on how to's) and the search normal temps.. your computer needs to run at a healthy temp or no matter how good your computer is it will overheat and become useless... but it can also be your processor or your about of ram... try deleteing old files you dont use to make disk space and after that go to start>all programs>accessories>system tools>disk cleanup.. and then after that is done system tool> disdefragment and let that run.... and if that doesnt help tell me and i can give more suggestions if it fails
12/10/2010 10:52:04 PM • Ubi Soft... • Answered on Dec 10, 2010
Lost the first CD
ok here you will find what you need so ckick and then choose a link: http://www.torrentz.com/a98f04c2fe9cc32d82fcf1bc0030c91aa0cff357
9/27/2009 3:49:05 PM • Ubi Soft... • Answered on Sep 27, 2009
Inserted cd clicked
this is the definition: The component qualifier not present.
This error occurs when a file compressed inside Setup.exe cannot be extracted. Verify that there is sufficient disk space available in the Temp folder (or, if not, in the Windows or WinNT folder), and that Setup can write to those folders.
7/8/2009 8:24:09 PM • Ubi Soft... • Answered on Jul 08, 2009
Game is not installing it gives error when it just
what is the error message?
7/7/2009 1:32:04 PM • Ubi Soft... • Answered on Jul 07, 2009
No sound for chessmaster 10th edition
You need to go to http://forums.ubi.com/eve/forums/a/tpc/f/760105752/m/5081052236 and download all patches in order.
If that doesnt work you will need to search the program file tree (Ubisoft/Chess/Data/User or something along those lines) for a CMDefault.ini cm.ini or YourName.ini (denoted by a notepad with a yellow gear superimposed) first MAKE A COPY OF THIS FILE AND NAME IT SOMETHING ELSE, then open the origional, and look for a modifer such as
sound=
or
playsound=
Or something like that...
If it is set to 0 or false then all you have to do is set it to 1 or true
THE SAME WAY IT IS WRITTEN
so if you see for example
sound=0
you will put
sound=1
NOT sound= 1 or sound =1 or sound= 11
Same for true / false
You also may see it either way
sound=true
sound= true
Save and try it, if the program crashes or fails to load, you made a mistake, delete the INI file and RENAME the COPY to EXACTLY the title of the ORIGIONAL.
And you'll be back where you started.
3/26/2009 2:01:27 AM • Ubi Soft... • Answered on Mar 26, 2009
Ubi Soft Chessmaster 10th Edition Logo
Popular Tags
36 questions posted
Top Ubi Soft Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Ubi Soft Video Game Consoles & Games
Most Popular Question
get error 1606
  • Video Game Consoles & Games
