20 Most Recent Lenovo IdeaPad Y510 - Intel Core 2 Duo 2.0GHz Notebook Laptops Questions & Answers
I have a problem while
Hi, It seems your hinge spring has broken. in short, you need to replace it. Good luck
9/15/2017 7:49:33 PM • Lenovo IdeaPad... • Answered on Sep 15, 2017
Blue screen
These WEB sites gives instructions on fixing the Blue Screen of Death. Fixing the Blue Screen of Death http://www.windowsanswers.net/articles/fix-blue-screen?tid=bluescreenexacthvgoogausnz http://www.maximumpc.com/article/features/blue_screen_survival_guide
1/4/2013 7:09:56 AM • Lenovo IdeaPad... • Answered on Jan 04, 2013
How do i burn photo's from pc to dvd disc
Download NERO and write them using this software
11/15/2012 9:15:08 PM • Lenovo IdeaPad... • Answered on Nov 15, 2012
Can not burn photo's from lenova 510 onto a dvd disc
Better do it using special software, for example you can download on torrent NERO software (write in google - NERO torrent) this software is easy to use, try it and if you have more questions - feel free to ask...
11/15/2012 9:14:32 PM • Lenovo IdeaPad... • Answered on Nov 15, 2012
Lenovo Y510 really slow
There are a number of possible reasons can cause your Lenovo Y510 computer running slow than it used to, it is hard to identify just what might be dragging down its performance, let alone implement the necessary technical adjustments to fix it. So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software.Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
9/3/2012 1:40:43 PM • Lenovo IdeaPad... • Answered on Sep 03, 2012
Lenovo y510 suddenly turns off and the funny thing
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
10/29/2011 8:45:26 AM • Lenovo IdeaPad... • Answered on Oct 29, 2011
I have a Lenovo Ideapad with a built in Lenovo
Hi kstrong,
I see that you need driver installed on you system, since you reinstalled windows on your Y510, make sure you check device manger on your system to see what driver you my need to install or probably you may need to reinstall all the drivers to make everything work fine on the Laptop.
below is a link where you can download your driver for your Y510 Laptop. http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=12
Once in the Download page make sure you only download the driver that is for the exact Windows on your system, it will say on the right side of each driver indicating what windows the driver is for.
I hope that this helps you with your concern, Reinstalling all your Laptops drivers will fix your systems devices and make them work properly again.
thanks have nice day.
4/9/2011 11:19:49 AM • Lenovo IdeaPad... • Answered on Apr 09, 2011
Lenovo y510 camera views upside down
go into your camera settings and, click on "invert image"
2/7/2011 3:30:47 AM • Lenovo IdeaPad... • Answered on Feb 07, 2011
2answers
Running out of disk space on C: on lenovo Y510
The Lenovo Y510 has a 250GB 5400RPM SATA Hard Drive, the only way to increase this is to purchase a bigger laptop hard drive from your nearest PC/Technology store. Take it in to their technitions and ask for assistance in the purchase of a bigger drive.
1/16/2011 10:45:04 AM • Lenovo IdeaPad... • Answered on Jan 16, 2011
The lid of my Lenovo Ideapad Y510 was slammed
I am sorry that the Computer is not booting. Please try accessing the BIOS by pressing the F2 key or Del key. In the BIOS windiow, press F9 to reset the BIOS to its default values. If you have the service manual of the Computer, please remove the back panel of the Notebook and reconnect the Hard Drive cable.
6/30/2010 3:40:17 PM • Lenovo IdeaPad... • Answered on Jun 30, 2010
Lenovo Ideapad Y510 HIGH SPEED USB port - Of the
both USB ports are 2.0 High speed ports.
6/24/2010 8:00:19 PM • Lenovo IdeaPad... • Answered on Jun 24, 2010
Y510 Idea Pad Lenovo Laptop
Hi. I think you could try updating the drivers for your DVD drive or by deleting the upper and lower filters on the registry so that we could verify if this a hardware or software issue. follow this instruction on deleting the upper and lower filters on the registry:
  1. Click the Start button and click in the Start Search box.
  2. Type regedit, and then press the <Enter> key.
    Note: The User Account Control window may appear. If so, click Continue. The Registry Editor window appears.
  3. Click the arrow next to HKEY_LOCAL_MACHINE.
  4. Click the arrow next to SYSTEM.
  5. Click the arrow next to CurrentControlSet.
  6. Click the arrow next to Control.
  7. Click the arrow next to Class.
  8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
  9. In the right-hand pane of the window, click UpperFilters.
  10. Click Edit on the menu bar.
  11. Click Delete. The Confirm Value Delete window appears.
  12. Click Yes.
  13. In the right-hand pane of the window, click LowerFilters.
  14. Click Edit on the menu bar.
  15. Click Delete. The Confirm Value Delete window appears.
  16. Click Yes.
  17. Click File, and then click Exit.
  18. Click the Start button.
  19. Click the arrow to the right of the lock icon.
  20. Select Restart.
If this doesnt fix the issue this might be a already a hardware issue, and from their you might want to clean the optical lens with cotton buds. Hope this helps
6/3/2010 8:53:56 AM • Lenovo IdeaPad... • Answered on Jun 03, 2010
I have a lenovo y510 and my camera works, but it
Try downloading and installing the camera driver from here.
Restart the computer to take effect.
6/2/2010 7:39:31 AM • Lenovo IdeaPad... • Answered on Jun 02, 2010
Lenovo Y510 Vista turns on, does not boot, does not turn off
Try hitting the F8 key and reboot in safe mode.
2/16/2010 2:09:47 AM • Lenovo IdeaPad... • Answered on Feb 16, 2010
My lenovo it keeps shutting down
hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
2/21/2009 4:27:15 AM • Lenovo IdeaPad... • Answered on Feb 21, 2009
How do I use the intigrated web cam on my new Lenovo laptop
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
1/24/2009 9:08:54 PM • Lenovo IdeaPad... • Answered on Jan 24, 2009
Startup problems/compaq presario 8000 series
Here is what I mean. You don't have to get one here, but here are what they look like.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2779&name=3.5-Enclosure-IDE&Nav=|c:2778|&Sort=0&Recs=10
1/16/2009 5:50:45 PM • Lenovo IdeaPad... • Answered on Jan 16, 2009
To test it is working okay, download and install Videocaster, and choose Capture Video from the main menu.
If you want to use it on Messenger or Skype, you have to select it as the default webcam in the video settings in each program.
Hope this helps
Chris (ziraffa)
ps Remember to rate this solution as Fixya!
1/9/2009 1:44:47 AM • Lenovo IdeaPad... • Answered on Jan 09, 2009
Lenovo IdeaPad Y510 - Intel Core 2 Duo 2.0GHz Notebook Laptops  Logo
26 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo y510 really slow
  • Computers & Internet
