20 Most Recent
Dell Inspiron 1318 Laptop Computer PC Notebook Questions & Answers
What is the mother board
It is a electronic circuit board with lots of electronic components. It controls the entire computer.
Battery not charging
this is just a suggestion not an appropriate answer
just try this!
try to unmount the battery from laptop and connect the battery, then mount the battery back to laptop
then leave the laptop goes off with out power then connect the adapter back to laptop and try to on normally.
Describe your wipe cmos dell inspiron 1318 laptop
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabledGo to:
http://dell-inspiron-1318-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Hello I have a dvd stuck and it will not eject is
If you laptop has the type of disk drive that actually comes out of it then you can use a butter knife and VERY GENTLY pry the drive out. If your laptop has the type where the disk goes inside the computer you will need to first SHUT DOWN YOUR COMPUTER, then remove the bottom of your laptop. DO NOT TOUCH ANYTHING EXCEPT THE DISK.
My computer says it dosent recognize my ac adapter
well introduce them(just kidding)check that the plug is seated on the adapter going into the laptopotherwise, there may be an issue with plug, adaptor or the place it insertsmight need a new adapter not that expensive really
Inspiron 1318 webcam issue
the software that you are using now for seeing the out of the camera may be corrupted.(I think so)just reinstall your web cam software for once
I have dell 1318 notebook
It would appear that you have a broken connection on the power connector on the motherboard of the laptop or a broken wire on the AC adapter. Repair of the connector on the motherboard could run about $125-$150 at a trustworthy repair shop. AC adapter replacement may be $25 over EBay.
If this information was helpful, please give a high rating. Thanks.
Black screen
from what it sounds like, you are looking at replacing one of two things. inside your screen is a backlight. depending on what type, (chemical tube or led, more often then not its a chemical tube they go quickly) number two item is your inverter. the inverter supplies the power to your backlight, usually located under the screen, attached to the metal frame of the screen(you have to remove the plastic framing) in other cases your inverter will be integrated into the motherboard, or it will be plugged into the motherboard. if its integrated, buy a new laptop as the motherboard will almost cost the same as the laptop. unless you want to risk damaging the screen to try and replace the backlight, i would go ahead and suggest looking up ebay for a inverter for your screen. you have no battery but you are plugged in directly. with this case i want to say its the inverter. but you need to know if its A) under the screen B) integrated C) on the mobo but not integrated. with A) you have a good chance of easily replacing it. with B) buy a new laptop. with C) you have to remove the faceplate with your plastic power button stuff and leds above the keyboard to access the keyboard screws. remove the keyboard and the inverter will be on the top left of the motherboard.
