20 Most Recent
Dell Inspiron 1420 Laptop Questions & Answers
Full screen minimizes on windows xp
Yvette Rodriguez,
I need a little more information on what you are describing. Please explain the process you are having with the Screen.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Scroll lock
It sounds like the touchpad wire wasn't reconnected..
My laptop won't hold a charge. have a new battery
Is the battery a genuine Dell battery? 3rd party batteries can be high quality or crap, just depends on the maker. Regardless, when you attempt to charge it, does it at least take a charge even though it won\'t hold it? Or does the battery refuse to accept a charge at all? When you plug in your laptop, does the charge light come on? Does the the battery level icon on the lower-right corner of the screen show it\'s plugged in? I know, lots of questions.
1420 bluetooth option
Hello dear, apparently you get (do not give much information about it) Control panel> Device and manager and see there devices that the computer has recognized, should not receive the bluetooh, you can include add device top left .
Why no sound
Anonymous,
First open up the sound properties icon on the taskbar and verify that nothing is muted. You can download and install the Audio Drivers for the Inspiron 1420 at the link below.
Inspiron 1420 Drivers
http://dell.to/1wRqjWS
Thank You,
Dell-Jesse L
DellCares
HOW TO RESET gOOGLE CHROME BROWSER SETTINGS
On the top right hand corner below the address bar there is an icon that looks like 3 bars one below the other, click on the icon, then select History, then select Clear Browsing Data. That done you can select all the reset functions that you wish to use.
Restore factory setting
John,Dell Factory Image Restore
The Dell Factory Image Restore tool replaces PC Restore. Access it from the F8 boot menu while booting up.
Once you have all the options on the screen, choose repair your computer and follow the prompts to restore.
CAUTION:
This utility formats the operating system hard drive partition prior to
restoring the factory image. This means data on that partition is deleted and
cannot be recovered.If the customer creates a secnd partition with a
third-party utility, Dell Factory Image Restore is not affected as long as the
image partition is not removed. Thank You,Dell-Jesse LDell Social Media and Communities
Forgot Login password and can not signin.
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
