20 Most Recent Kyocera FS-3900 DTN MONO LASER PRINTER Questions & Answers
Call service 61300400573
are you sure this is the error code?? normally its only 4 digits
6/30/2012 1:39:40 AM • Kyocera FS-3900... • Answered on Jun 30, 2012
0answers
Although no jam seen and
Easy. You have to seek the problem at the left side underneath the the gears.Turn it to the bottom.There is a protruding metal peace. Bend it back to stand vertival. It will slow your problem, but if not feel free to ask!It helped to me.
10/11/2011 6:22:39 PM • Kyocera FS-3900... • Answered on Oct 11, 2011
2answers
Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
9/25/2011 6:45:58 PM • Kyocera FS-3900... • Answered on Sep 25, 2011
Kyocera 1750 error 6000: 0002930
6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
6/16/2011 9:54:29 PM • Kyocera FS-3900... • Answered on Jun 16, 2011
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
5/28/2010 5:09:43 PM • Kyocera FS-3900... • Answered on May 28, 2010
6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
1/10/2009 2:16:27 AM • Kyocera FS-3900... • Answered on Jan 10, 2009
Kyocera 3900 dn, is there
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
1/10/2009 2:12:06 AM • Kyocera FS-3900... • Answered on Jan 10, 2009
Kyocera 3900 dn is printing slow
Turn off RAMDISK.
12/28/2008 8:24:37 PM • Kyocera FS-3900... • Answered on Dec 28, 2008
How to get the Kyocera printer from offline to online
11/8/2022 6:34:41 AM • Kyocera FS... • Answered on Nov 08, 2022
I am recieving machine failure on kyocera 4200 dn
The most common machine failure codes is CF---. For example CF248, CF000. In the most cases the printer is need to be upgraded to the latest firmware.
9/25/2019 7:47:35 AM • Kyocera FS... • Answered on Sep 25, 2019
2answers
HOW DO I RESET CODE ERROR-KYOCERA FS1035
Suggestions at the link below: Thread Kyocera FS 1035 error C7990
4/30/2019 4:24:29 PM • Kyocera FS... • Answered on Apr 30, 2019
I cannot get the cassette tray 1 to change from legal to letter sized paper. When I use the command centre, there is no drop down available to change it.
make sure your cassette paper guides are snug to paper or push the system/counter button look under common settings and change the size to letter
3/3/2018 8:37:57 PM • Kyocera FS... • Answered on Mar 03, 2018
Kyocera fs 1016 mfp Was ok till the start button didn't work, is it possible to repair it ?
Mrs lina p try to use WD40 I think it will help you
10/18/2017 6:50:35 PM • Kyocera FS... • Answered on Oct 18, 2017
Kyocera FS-3900 DTN MONO LASER PRINTER Logo
20 questions posted
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
kyocera 3900 dn
  • Office Equipment & Supplies
