20 Most Recent eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop Questions & Answers
Download the Chipset driver on eMachines Website.
eMachines T3656 Driver Download
Select Product Family: Desktop
Select product Line: T Series
Select Product: T3656
Operating System: Select the version of your OS
Click on the Driver Tab
Download and Install the Chipset Driver
Thanks for using Fixya
eMachines T3656... | Answered on Aug 28, 2015
is this a crt monitor (bulky glass screen) or a panel type?
eMachines T3656... | Answered on Apr 17, 2014
What do you mean? Do you want to know what CPUs are supported by the board in order to select an upgrade or what?
eMachines T3656... | Answered on Feb 02, 2014
windows update or pc world who make emachines.
eMachines T3656... | Answered on Jan 29, 2014
ANDREW WHAT KIND OF KEYBOARD ? .PS/2,USB OR WIRELESS.
eMachines T3656... | Answered on Dec 16, 2013
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
eMachines T3656... | Answered on Sep 06, 2013
http://www.innovative-sol.com/drivermax/
GOOD FREEWARE PROGRAM.FOR DRIVERS.
DO A SCAN.
eMachines T3656... | Answered on Jun 07, 2013
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
eMachines T3656... | Answered on Jan 11, 2013
not a netflix issue in fact most likely amount of memory needs to be increased
check mem this way
start button
control panel
system icon
shows memory
let us know results then step 2
eMachines T3656... | Answered on May 29, 2012
hi there,open up the side of your case(you may have to unscrew a few screws) and look fo it..
If you do not no what it looks like heres one:http://plone.lucidsolutions.co.nz/dvb/t/images/IMG-0323%20Quad%20Tuner%20Card%20in%20PC.JPG
Just press down on the latches on either side of it to ''unlock'' it frmo the pci board,then just simply lift it out(make sure that your monitor/Display cables are not plugged in at this point and that your pc is powered down)..Good luck and Please rate me
eMachines T3656... | Answered on Feb 03, 2011
Hi ,
Unfortunaly , you can't . You need the install disc . You can retreive existing data by extracting the hdd from your desktop and connect it to a healthy computer . Format the HDD afterwards , put it back into the desktop and launch install disc .
eMachines T3656... | Answered on Jan 22, 2011
This indicates you have no resident restore partition on your hard disk drive. The easiest way is to put your Windows OS CD in the PC and startup. It should ask if you want to start from CD. Say yes and follow the instructions. You may need to press F2 or 10 to change the bootup sequence to start from the CD if it doen not do it automatically.
Thanks
eMachines T3656... | Answered on Jan 06, 2011
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
eMachines T3656... | Answered on Dec 13, 2010
Two factors why you are getting that problem;
-- Operating System (windows is corrupt) or
-- installed memory is defective
..try to swap other memory on your computer or also try inserting your memory to other PC to determine if its working or not, if the problem still exist try to reformat your PC maybe its the Operating System is having the problems.
eMachines T3656... | Answered on Jul 11, 2010
Two separate issues. Do you mean you don't have enough system memory? Look up the system requirements for the game your trying to play. You did not list what OS your using. If its XP, try increasing the Virtual Memory. You do this by right clicking on "My Computer" Go to "Advanced" In the "Performance Options" click on "Advanced" There you can increase your Virtual Memory. Also check and clean out your "Startup" by clicking on "Start" then "Run" Then type in the word msconfig
Then click ok. Go to the "Statup" tab and clean out what you do not need.
eMachines T3656... | Answered on Apr 26, 2010
if the network card in onboard or on pci slots then install the appropriate driver
eMachines T3656... | Answered on Apr 20, 2010
first off copy the image from your camera to your computer's desktop then go to face-book and upload image then chose the pic on your desktop
eMachines T3656... | Answered on Mar 17, 2010
Hi
How will you remove the virus some viruses are not remove buy virus scanner only. The proper way to remove all viruses are to reformat you personal computer. You need to have a fresh copy of windows operating system. Reformat your computer just load a windows CD to your CD room drive.
eMachines T3656... | Answered on Feb 26, 2010
I believe this is the diagram for your motherboard: fe7147a.jpg
http://support.gateway.com/emachines/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Either of the two yellow USB connectors labeled R in the picture should work.
eMachines T3656... | Answered on Jan 07, 2010
eMachines T3656 Celeron 440 1GB DDR2 160GB Intel GMA 950 Windows Vista Home Basic PC Desktop Logo
40 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
deleted much stuff off 1g emachine
  • Computers & Internet
