20 Most Recent
Epson DC-10s Digital Camera Questions & Answers
I have an old Epson
It's ancient, worthless and totally obsolete. Spare parts will be impossible to obtain. Repairs will be completely uneconomical if you have to pay for them in any way (parts or labour).
In short, you have absolutely nothing to lose by trying a DIY repair, and even if it fails (highly likely) you gain valuable experience for when you next attempt such a repair.
BTW: the Epson 850z is not an SLR. The optical viewfinder does not take it's image from the same lens used to take the picture.
NO. THE PROBLEM IS THAT THE SWITCH CANNOT TURN ON
There may be many possibilities that can cause this.Here is what you can check:
Initially remove the battery and reinsert it again and check if it works.also try using other battery if you feel battery might have gone faulty.
Also possible that the switch may hve gone faulty or the internal connection to switch is loosened up.
Open the device and check if the switch is internally stuck.if the connections are faulty,Just resolder the connections properly and try again.if the switch looks damaged or faulty internally.Replace the switch.
thanks and please do not forget to accept the solution
Need a driver
hi gbolshoy,
why do you need the drivers for by the way? is it for transferring picture / videos from the camera to your computer?
olympus did not create drivers for the device but only the application to manage the media. looking forward to your reply.
regards,
voodoo
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
