20 Most Recent
Maxtor OneTouch II 300 GB Hard Drive Questions & Answers
I had off and on
because of the power off on that will have messed up your trans-fare in that it will have corrupted your hard drive if you can still access the drive reformat it then use a recovery software to get the deleted files even when its been formatted it still leaves a fingerprint so the files may still be there
Can restart my magicjack
what do you mean by not being able to restart and what operating system do you have? you can format the magic jack itself to reset it. open my computer and look for a drive that says vista or phone, right click and format. Then install any updates. let me know if you need anything else
seth
Light flashes continuously
The external drive has gone belly up. You can try it on another usb port and also on another computer just to satisfy yourself, but the drive has croaked.
I uninstalled to start over
It could be that it
is mapped to a drive letter that is already in use. Under device
manager, (right click my computer and select manage then click on disk
management) If you see the device in there then you can right click on
the bar graph representation of the disk and select to change drive
letter and paths. This will allow you to remove the conflict and have
it show up again.
Disk Full 51 Restore points
> 51 restore points [exist]
Delete some of the "older" restore-points, to make room for more restore-points to be written.
I dont remember the maxtor
Inorder
to reset the BIOS password, you have to open the laptop from the back,
locate the CMOS battery, remove it and press down the terminal (with the
help of a screw driver) for 5 sec, now turn ON the computer (keepon
holding the terminal) short the BIOS. Now, Turn off the computer and
restart the computer, it will reset the BIOS password.
Thanks and regards,
Anil.B.R
My external hard drive is 300g,i formatted my
do you have a recovery disk for the internal hard drive? this is the disk that came with pc.your internal HD is important this have been wiped (you have no OS) . get your internal back in order........do you have a receipt that says you purchased a 300gb (not 3gb) take it back get your money or the right external... once you are able to use the pc double check the external hard drive
The blue light on my Maxtor is blinking really
Have you tried restarting your Mac (with the Drive still connected)?
Otherwise try:
1. Disconnect the USB cable from your Mac.
2. Restart your Mac.
3. Reconnect the USB cable to a different USB port on your Mac (like the keyboard USB port for example).
See how you get on. Let me know. Regards,
I have a maxtor icon with a lock on it. I click on "unlock" and nothing works
Have you tried right clicking on the drive and going into properties. Click on security option and make sure that all the permissions for the drive are active with the exception of special permissions. Also look at the advanced security settings and make sure that you have full control permissions. Hope this helps.
