You control the answering machine from the handset. First turn on the answering machine. Press Menu then use the up/down arrows keys to navigate to Ans Machine. Press OK then navigate to Answering M. Look for a check next to this to indicate it is on. Press OK to toggle the answering system on or off. Then press End or left arrow to return to the previous menu. If the machine's memory is full, it will switch off. Delete messages so that the unit will keep the answering machine feature on.
Next to record a new message follow the above steps to reach the Ans Machine menu and press OK. Scroll to Announcements and press OK. Scroll to Record Annc or Rec Annc Only (if no messages will be recorded). Press OK then bring the handset to your ear and listen for the notification of recording and then the tone. State your message clearly into the microphone of the handset. Press End to stop recording and listen to the unit play back your announcement. (It will stop automatically after 170 seconds or a 2 second pause in your speaking.) If an Annc Only message is available, the machine will play it when the memory is full. Otherwise, it will turn off.
To select your announcement (and recording type) follow the above steps to Announcements and press OK. Then scroll to Mode and press OK. Scroll to Annc or Annc Only (available if the Announcement only recording has been made) then press OK. Again OK toggles the announcement on or off; look for a check mark to indicate the announcement will be played. Press End to exit the menu.
Retrevo has the manual for the Gigaset 4215 here:
http://www.retrevo.com/support/Siemens-4215-Telephones-manual/id/23319bh144/t/2/ . You will need to enter a code to download the file.
I hope this helps.
