20 Most Recent
Palm Treo 800w Smartphone Questions & Answers
I want to use my wifi feature to connect my
If you mean you will use your phone as a modem to connect your computer to the internet please follow these steps.
Setting up a USB Internet Sharing connection
- Note: BEFORE YOU BEGIN Make sure your phone is on and that one of the data services icons appears at the top of the screen. If you don't see either of these icons, you cannot use your smartphone as a modem.
- On your computer, open ActiveSync or Windows Mobile Device Center.
- Click File > Connection Settings, and make sure the Allow USB connections box is unchecked.
- Connect your smartphone to your computer using the sync cable.
- On your smartphone, press Start and select Today. Select the Internet Sharing icon.
- Select the PC Connection list, and then select USB.
- Press Connect (left softkey). When your computer detects the connection, an icon appears in the taskbar in the lower-right corner of your computer screen.
- On your computer, open your web browser to confirm that you can connect to the Internet.
You can visit the site here for more details
Have a palm treo and
Well you need to unlock your palm, You can please follow the below link to get the unlock code -
http://www.thetravelinsider.com/roadwarriorcontent/treounlocking.htm
(Just copy and past the above link in your web browser)
Good Luck!!
Thanks
Will receive, but won't send text messages
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
90% of the time when
Well first of all you can try to reset it, goto menu/settings and then select the reset option, (note. resetting the phone will erase all the data from your phone and set all the settings to factory default). the problem seems due to low memory, so you can also try to remove some unused data from the phone before going to reset it.
Good Luck!!
Thanks
My palm treo won't send text messages
the problem is on your message center number so contact your service provider for message center number.
And replace/ edit the setting number.
For this goto Message---> text msg Setting
What is the best way to dry out a plam that has
if you can,open the unit and put on a table against the wall to let it stand for 24 hrs.thats why the liquid on it will be drained,then after the given time,you get a hair blower and blow it in just a minimum heat of the blower for about 30 seconds.you can perform a distance of the blower and the unit of about7 inches in between them.
HOW CAN I UNLOCK MY PALM TREO750 FREE OF COST
You can't unlock your PALM TREO 750 for free of cost. Most of the free offers available online are looking to be scam and it would affect your phone. You can get unlock code for a TREO 750 at affordable cost. You can get the unlock code for your mobile from
www.Theunlockspot.com . this is one of the legit site providing accurate unlock codes at most affordable cost with easy unlocking instruction guide. All the best mate.
