20 Most Recent
LG KP200 Cellular Phone Questions & Answers
LG KP200 Security Code?
IMEI: 55590010817329
it is very simple to
Unlock your LG KP200 by entering Imei Unlock Code . you can get your Mep Unlock Code for LG by third party or your network provider.third party give your Imei Unlock Code within hour. but your network provider take time to give you Imei Unlock Code. and charge huge amount. you can buy
LG Imei Unlock Code from third party. they will charge little amount.i hope this will help you.
2/11/2012 7:13:34 PM •
LG KP200...
Answered
on Feb 11, 2012
Hi when i insert barrery
See if the batter fits in its place tightly, correctly and isn't loose.
Apart from that it is obviously a hardware related problem and I believe you should take your LG to the nearest sales and service center to get it fixed.
5/27/2011 7:37:21 AM •
LG KP200...
Answered
on May 27, 2011
Lg KP199 phone reboots automatically during call :(
Could be a viral infection. To get rid of the virus you must get the firmware reinstalled from LG Service Center only as when they do it, complete firmware is rewritten. and the virus gets overwritten. Then install an anti virus prog even if you are not using the inetrnet, you are using the BT which can also download viruses from other phones.
5/24/2011 4:17:12 PM •
LG KP200...
Answered
on May 24, 2011
My lg kp230 mobile phone
replace the battery with new one , then check if it doesnt help .then there is a procedure called flashing .. its a technique .. search the internet for this
do vote if it helps
3/31/2011 1:58:54 PM •
LG KP200...
Answered
on Mar 31, 2011
I want to connect my phone to my pc. so i need pc
LG has a Mobile Support Tool which you need to install, then enter some details about your phone to get the correct software to be able to connect it to your pc. You can download the support tool from the below link -
LG Support Tooland below the boxes for model name and search there is a Download button for the mobile support tool. You can also select Download at the top of the screen to show more detailed instructions on how to download and use the support tool to get PC Sync working.
Thx, if this solution helps please rate :)
1/30/2011 11:39:48 PM •
LG KP200...
Answered
on Jan 30, 2011
How can use themes on lg kp220
Quick installation instructions: * Download the LG theme and unzip it on your PC or Mac
* Transfer the theme files across to your LG phone using an USB cable or Bluetooth and you are done
* You can also set the image files as your preferred Main screen, start-up screen and shutdown screen
Downloads
9/30/2010 4:59:24 PM •
LG KP200...
Answered
on Sep 30, 2010
When i connect USB
simply change the usb cable. may be the usb cable was already damaged
8/7/2010 1:39:10 PM •
LG KP200...
Answered
on Aug 07, 2010
Mic not working
Hi, what to do if the speaker does not work. Get a set of screws that will loosen the phone, Go to where the speaker is, try and clean it up and use a battery to test if the speaker is working.
After checking the speaker,if it is not working, That means you will need to replace the one inside with a new speaker.
I would advice, if no experience of how to loose the phone, Get a technician in phone to do it for you.
Take care.
6/15/2010 2:59:01 PM •
LG KP200...
Answered
on Jun 15, 2010
