20 Most Recent
Nokia N77 Cellular Phone Questions & Answers
My n77 is lock from smart how do i open line?
unlocking a phone through codes is the best and simple way to unlock a phone. get your codes either from your service provider or from other third party provider who provides codes at reliable rates. i got the codes for my nokia m70 phone from here.
Prounlocking.com
4/26/2013 8:32:25 AM •
Nokia N77...
Answered
on Apr 26, 2013
How to remove the housing of N77 phone
- ower off your cell phone completely by holding down the power button for four or five seconds. Turn the phone over and remove the back plate. Slide your fingernail underneath the battery and pop the battery out of the phone
- Locate the SIM card if your mobile phone is a GSM style phone. Pull back the metal covering over the SIM card and then remove the card. Set it aside
- Removing the RF grommet,Find the plastic RF grommet at the bottom of the phone near where the battery was located. Grab the grommet with a pair of tweezers and remove it from the phone
- Removing the bottom cover, Insert the tweezers into the hole on the side of the phone opposite from where the RF grommet was located. Use the tweezers to pull up on the latch inside the hole to unlock the bottom plastic antenna cover. Lift the cover off of the phone and set it aside
- Metal plate, Pull out the screws along the edges of the phone using the Torx screwdriver. Take the metal plate off of the phone
- Flip the phone over so that you can see the LCD screen. Slide the edge of a flat head screwdriver in between the seam of the plastic cover on the bottom of the phone. Wiggle the screwdriver up and down gently to unlock the catch underneath the plastic cover. Lift the entire plastic cover up and then off the phone
- Find the latch on the side of the LCD screen and unlock it with the tweezers. Pull the screen slightly off of the phone and then disconnect the cable running from the screen to the phone. Lay the replacement screen back into the phone and attach the cable
- Set the plastic cover back onto the phone and then flip it back over. Re-attach the metal plate and put the screws back in. Push the RF grommet back into place and then place the SIM card and battery back in the phone. Put the plastic cover on the back off the phone and then power it on to ensure the screen is working correctly
11/21/2011 5:40:03 AM •
Nokia N77...
Answered
on Nov 21, 2011
I forgot my password on
If you forgot the security password, then you need to master reset the
phone. I recommend you to contact your service
provider to get the master reset code or you can get from online.
7/18/2011 10:10:23 AM •
Nokia N77...
Answered
on Jul 18, 2011
I cannot active my animated
Since you are using Symbian S60 operated phone, you need to sign the application that you want to install, that includes themes. With that, you may download a freesigner application. Try searching it on the web. Cheers!
7/7/2011 7:16:45 AM •
Nokia N77...
Answered
on Jul 07, 2011
N77. it says it says
The memory full error comes not because of memory card. It comes because the internal memory is full. There was no need to format memory card. you have to format the internal memory.
Here is the procedure:
1. Take backup of your contacts and messages because they will be DELETED after formatting
2. Dial *#7370# from your phone. It will ask to format. Press yes
3. It will also ask the pin or password. The default password is 12345.
The phone will restart and the memory full message will disappear.
6/2/2011 6:38:56 AM •
Nokia N77...
Answered
on Jun 02, 2011
Camera silent mode
Dear user!
Its very tricky, nowadays its impossible to make camera sounds silent on Nokia for issues well known :)
but there is always an alternative camera application that you can use which may click pictures silently for example nimbuzz chat application
5/13/2011 4:00:25 AM •
Nokia N77...
Answered
on May 13, 2011
Delete some data..
i cannot use
try deleting all your messages including your inox,outbox, sent items folder, darfts and etc.. you may have a memory full storage for your messages.. or it may have some software problems.. try flashing your phone on a nearby phone repair shop.contact me if you have other questions.. o9l8 45o 554sven
3/30/2011 2:40:49 AM •
Nokia N77...
Answered
on Mar 30, 2011
N77 cannot send sms memory
Format your mobile
follow this procedure
Press and hold * 3 and Green call button and power button at one and hold them untill it format
its called hard format
then new factory setting will be replaced
3/16/2011 9:51:53 AM •
Nokia N77...
Answered
on Mar 16, 2011
