20 Most Recent
Maxtor OneTouch II 100 GB Hard Drive Questions & Answers
Re: Maxtor External 100GB one
Hi
check this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
thank you
I have the hard drive,
well connect the hard drive to your computer by the USB
and run the installation CD provided.
that should be it
Errors when Backing up information from hard drive.
I have several drives backed up and they work fine whenever they are imaged. anyway..
These drives are made for use in Windows and Mac enviorments. It is usually MAC users that have this problem.They are usually preformatted using fat32. because the drive is usually for storage fat32 is sufficent...but there are certain characters that fat32 dosen't care for...Do you have file naming scheme that uses odd characters? if so Those are the file names the error is refferring to. You may choose to reformat the drive using fat32(again) or NTFS(note fat32 has a better chance of data recovery just in case)your main hard drive might be NTFS.
The rest is only important if you use a MAC
Now if you have a MAC see below.
How do I initialise the external drive for Mac OS X?
Preparing the Seagate/Maxtor external hard drive in Mac OS X
Mac OS X cannot mount a FAT32 partition larger than 137 GB (128 GB binary value). Our partiton is 160 GB (149 GB binary value). Since your external drive comes with a large FAT32 partition preinstalled you will need to initialise the drive to use it in Mac OS X.
WARNING: Initialising or partitioning the drive will erase all data on the drive. If you have used this drive on another computer take the drive back to that computer and copy all data off of the drive before proceeding.
When the drive was plugged into the Macintosh you probably noticed a message reporting an error that it cannot read the volume. At this point you have the option to initialise the drive. If you missed that message you can initialise the drive manually.
Initialising the drive in OS X
If you see the volume error, you can click the Initialise option. If you do not see it, then go to Finder > Applications > Utilities > Disk Utility.
In Disk Utility: Select the external drive (149.05 GB). Be sure you select the correct drive before proceeding. If you have more than one 160 GB drive then be sure to select the correct one.
1. Go to the Erase tab.
2. Choose the type of partition (Mac OS Extended).
3. Type a volume label.
4. Tick the box that says "Install Mac OS 9 drivers". If this option is not selected, this device cannot be used by a computer running Mac OS 9. This option does not affect Classic.
5. Click Erase.
6. Read the prompt and Click on Erase again if you agree to erase all the data and you are sure the correct drive is selected.
7. The drive will now show on the desktop with a Firewire icon and the volume label as the name.
Additional Information
For more information on the FAT32 partition size limit in Mac OS X please read document number 107483 on Apple's support web site.
For more information about formatting drives in Mac OS visit Apple's support web site.
For more information about decimal versus binary capacity values visit our FAQ on the subject.
Let me know what happens.
Good Luck,
Tim
Maxtor External Hard Drive No Power
I assume it is a USB connection? Does it also have a power adaptor or a USB dongle that has 2 USB connectors? If you cannot get it to power up, the only other option to retrieve your data is to take the HD out of the case and connect it to a PC or laptop using a SSD or SATA to USB adapter and see if you can get the PC to recognize it.
