20 Most Recent Weiser Lock POWERBOLT ELEC DEADBOLT Questions & Answers
Deleting Codes on a Weiser powerbolt.
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspxNotice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:http://get.adobe.com/reader/
11/13/2018 3:34:00 PM • Weiser Lock... • Answered on Nov 13, 2018
3answers
Have to change the key code? No manual.
You can change codes as often as you like, for use by babysitters, contractors, etc. You can also reset the lock so you can reset the master code, which is needed in order to set the other user codes.
Rather than re-type all the step-by-step instructions, since you also could benefit by having a copy of the manual for your use and reference, I'll give you a link to a free copy you can save and print.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful and best regards!
5/11/2018 8:07:05 PM • Weiser Lock... • Answered on May 11, 2018
Hi,,My weiser powerbolt elec deadbolt has been
i have the same problem in northern canada... did you find a fix yet
10/12/2017 2:01:03 AM • Weiser Lock... • Answered on Oct 12, 2017
2answers
Replacing powerboat, new one not
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
2/15/2016 6:51:45 PM • Weiser Lock... • Answered on Feb 15, 2016
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first. http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
5/24/2014 7:36:09 PM • Weiser Lock... • Answered on May 24, 2014
0answers
0answers
0answers
0answers
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
149 questions posted
Top Weiser Lock Locks & Locksmithing Experts
Sean Wright
Sean Wright
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
View Most Popular
  • Weiser Lock Locks & Locksmithing
Most Popular Question
need change code
  • Locks & Locksmithing
