20 Most Recent
Shakespeare Surf Fishing Rod and Reel Combo Questions & Answers
Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Instruction manual for b-mag 1000
momot-guitars.com/en/.../shimano-
b-
mag-
1000-fishing-reel-
manual?...
Jul 22, 2015 - Download Shimano b-mag 1000 fishing reel manual >> Download ...
I have a shakespear alpha fishing reel which
The switch is the on/off anti reverse switch. It is the switch (probably the only one) on the reel at the base. When the reel is in the upright position, look at the bottom/rear area. That little level controls the reverse. Good fishing...
User manual
can not get control panel to work on hydro massage spa model ALCOY Aqua4fun style gold
I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
