20 Most Recent York Yankees Bedding MLB Comforter Questions & Answers
2answers
I have a York T710 Platinum series treadmill and
hi , i have most manuals what is it you need to know
please email me on [email protected]
and i can send you the manual
Kind Regards
Joe
2/24/2023 10:45:27 PM • York Yankees... • Answered on Feb 24, 2023
3answers
Cable diagram york home gym 4180
Call York at 1-800-361-0448 or 1-905-827-6362. I believe they have all instruction books for all of their home gyms.
9/4/2020 7:38:55 PM • York Yankees... • Answered on Sep 04, 2020
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
10/17/2017 9:52:29 PM • York Yankees... • Answered on Oct 17, 2017
I have low suction problem in my yciv chiller
Low suction pressure normally , happens when the system go low in refrigrant . but some times it happens if on of your drain or feed valves malfunction , cause of a mechanical or electrical problem with one of the valves. or error , that you read on the display the valve is open ...percent . but realy it is not.
7/20/2017 4:57:35 PM • York Yankees... • Answered on Jul 20, 2017
3answers
I have a york stellar
Hi try jumping out the pressure switch see if it lights and check th rair filter might need a clean
11/13/2015 3:43:26 AM • York Yankees... • Answered on Nov 13, 2015
I have a york furnace
Probably the flame sensor is dirty. Should be wire protruding into flames opposite end of flame tubes from igniter. Clean with steel wool.
11/13/2015 3:26:16 AM • York Yankees... • Answered on Nov 13, 2015
How to setup a york kompact 800
You can obtain the manual from York fitness (email support) or I can email it to you
6/20/2015 7:45:34 PM • York Yankees... • Answered on Jun 20, 2015
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
5/12/2015 7:48:31 PM • York Yankees... • Answered on May 12, 2015
York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
4/17/2015 10:41:47 PM • York Yankees... • Answered on Apr 17, 2015
Where is the furnace filter located on the York
Residential furnaces have exterior filter boots supplied by installer, commercial york units have filter access doors. If this is a roof top unit your filters would be in the door to the left of the blower compartment.
1/9/2015 7:57:56 PM • York Yankees... • Answered on Jan 09, 2015
Venting on a York Furnace
about 18 inches
12/9/2014 4:36:30 AM • York Yankees... • Answered on Dec 09, 2014
York Yankees Bedding MLB Comforter Logo
207 questions posted
Top York Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • York Sport & Outdoor - Others
Most Popular Question
cable diagram york home gym 4180
  • Sport & Outdoor - Others
