20 Most Recent Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Questions & Answers
I HAVE A T1200 WITH KOHLER ENGINE. / ON ALL THE LOWER GEARS THE TRANSMISSION? GIVES ME A DONKEY RIDE ! AS IF THEIR IS PLAY IN THE TRANSMISSION: IS IT THE TRANSAXLE THAT IS WORN ?
POSTED TO CARS/TRUCKS MOVED YAH TO WILD GUESS ME, The Craftsman T1200 two-wheel drive lawn tractor was manufactured by MTD built from 2015 to 2020. The components of Craftsman T1200 powerline system: 25.6 cubic inches (420 cc) Zongshen 4P90HU 4-cycle single cylinder 2-valve vertical shaft air-cooled gasoline engine and mechanical CVT transmission with infinite forward and reverse gears. The engine has a float carburetor, splash lubrication system, and electronic ignition system. The maximum travel speed (forward/reverse): 5.5 mph (8.8 km/h) and 2.3 mph (3.7 km/h).
4/20/2023 12:15:32 PM • Craftsman 42 in.... • Answered on Apr 20, 2023
2answers
My Craftsman lawn mower won't go forward or backwards.
Have you checked the belt from the engine to the transmission see if it is bad.
4/21/2022 2:02:54 AM • Craftsman 42 in.... • Answered on Apr 21, 2022
2answers
I have a 24hp vtwin B&S engine. I need to know whether to make the valve adjustment with the engine hot or cold. Would please answer with this information? Thank you.
you can set the clearances cold but the measurements will be .002" bigger to allow for valve stem length increase when hot example --a setting of .012" hot will be .014" cold Hot is best as the stems do not always expand uniformly so valves in one engine may expand more or less in another engine always check the clearance when hot B&S engines are noted for valve stem stretch for a period from new so a regular monitoring of the hot clearance is a good idea ( check say every 20 hours operation for the first few periods until the clearance remains steady)
10/2/2016 7:36:48 AM • Craftsman 42 in.... • Answered on Oct 02, 2016
2answers
The engine starts and the blades can turn. Both of
Hello, the mower was driving before you hit the root? If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
5/23/2015 12:42:28 AM • Craftsman 42 in.... • Answered on May 23, 2015
How to replace mower deck bearings on a craftsman 24hp with 42" cute
GAO TO YOU TUBE Replace spindle bearing Craftsman 24hp
9/9/2014 12:14:41 AM • Craftsman 42 in.... • Answered on Sep 09, 2014
2answers
Why does my zero turn mower struggle when trying to cut grass, it seems to be using half power.
If is a twin cylinder engine this could be very well the problem. Without the engine info it is hard what it could be.
7/23/2014 8:23:08 PM • Craftsman 42 in.... • Answered on Jul 23, 2014
Bled on cutting deck spins free and will not cut
Hi there, I assume you mean the blade on cutting deck? Is the pulley that drives it still firmly connected to it? (I mean the pulley and the blade spin together as one, and not independently) If the blade is loose on its spindle check under the deck for damage, and that the blade securing bolt(s) are intact and tight. If the problem is that the pulley isn't getting driven by the deck belt, that is a different story. Most likely the deck belt isn't getting enough tension to grip the pulley. Check the tensioner is working properly and the spring is still hooked up and working.
5/26/2014 6:26:58 AM • Craftsman 42 in.... • Answered on May 26, 2014
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
5/10/2014 6:16:29 PM • Craftsman 42 in.... • Answered on May 10, 2014
As I was mowing I began to notice that my tractor losing power and couldn't make it up the slightest hill. Today it seems to have gotten worse and smells as if it is overheating.
Look to see if a mouse nest is blocking your cooling fins. The smell could be the nest.
4/14/2014 11:48:49 AM • Craftsman 42 in.... • Answered on Apr 14, 2014
Mower blade on one side spins free and will not
Check the bearings in that spindle.
9/7/2013 3:09:05 PM • Craftsman 42 in.... • Answered on Sep 07, 2013
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
75 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
24hp vtwin b s engine need know whether
  • Garden
