20 Most Recent Miller matic 140 Mig Welding Package W/As 907335 Questions & Answers
2answers
I have a lincoln 140 pro mig welder.I am useing 35
Your Linner of the gun could have a kink in it.
12/3/2014 8:31:48 PM • Miller matic 140... • Answered on Dec 03, 2014
Name of part wire travels through
liner into torch then swan neck and finally through the tip
11/4/2013 12:23:26 AM • Miller matic 140... • Answered on Nov 04, 2013
Electrical wiring
The CP-300 and CP-200 were never designed to run on single phase. You can buy a 3-phase generator (see military surplus) or a phase converter. You will need a pretty big one - like one rated for 20hp to use the full potential of the welder. That is also pretty expensive - say $1000. However, if you have a shop, you can buy used 3-phase equipment sometimes significantly cheaper than 2-phase stuff. So you buy that expensive converter and save money on all the other equipment you will buy. Or sell it. Or scrap it - some older welders had big copper wound transformers - a few hundred bucks worth of copper.... some had aluminum though... Good luck.
10/24/2013 2:12:28 AM • Miller matic 140... • Answered on Oct 24, 2013
I NEED A BREAK DOWN
Follow this link...http://www.millerwelds.com/om/t225716g_pt_mil.pdf
or copy and paste it at your web browser.
1/13/2011 4:50:09 AM • Miller matic 140... • Answered on Jan 13, 2011
I have a millermatic 130 and the wire keeps
First thing to check is that you still have an inlet guide (plastic funnel like) before the drive rolls. This one can be dirty or have enough build up inside that makes the wire feed imposible. Change this one if possible, it will cost you around 5 bucks at your near welding shop. If everything looks ok, then make sure you have the right drive rolls size, 023 or 030 in this case. Then ckeck you liner if it has a kink or dirty in the inside (use compressed air to blow the inside of the gun) then it's useless, change it. Final will be the contact tip just replace it for the right size according to the wire size.
1/9/2011 6:15:58 PM • Miller matic 140... • Answered on Jan 09, 2011
Do you sell these and what is the price
579 at any praxair location.
1/2/2011 9:30:28 PM • Miller matic 140... • Answered on Jan 02, 2011
Hello, I have had a mig welder for some time and
well theres a couple things it could be. first make sure the surface is clean. second check the type of metal the horseshoe's are made of. its really hard to get welding to stick to pot metal.
1/1/2011 5:33:26 AM • Miller matic 140... • Answered on Jan 01, 2011
The welder will shock you through the handle while
Check inside grounding, if everythinbg looks good, need to be service by a pro.
12/18/2010 10:40:45 PM • Miller matic 140... • Answered on Dec 18, 2010
My Millermatic 140 Auto Set, which is run by a
fan or relay problem welder is protecting itself from burning up when it cools off will run fine check relay or fan
12/17/2010 3:34:28 AM • Miller matic 140... • Answered on Dec 17, 2010
My welder turns on, when I press the botton the
check that its got a good earth,,then strip the handel and check the triger switch
12/1/2010 9:57:55 PM • Miller matic 140... • Answered on Dec 01, 2010
I have a wire feed welder that is not feeding wire
Make sure that wire feed wheels are tight and the tip is clean
11/20/2010 2:44:16 AM • Miller matic 140... • Answered on Nov 20, 2010
My lincoln 140 welds fine
You may be exceding the duty cycle of your welder
Check your operstors manual to see how long you can weld at higher amps before giving the welder a chance to cool down
10/18/2010 1:31:59 AM • Miller matic 140... • Answered on Oct 18, 2010
Miller matic 140 Mig Welding Package W/As 907335 Logo
47 questions posted
Top Miller Welding Tools Experts
Sean Wright
Sean Wright
john h
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Miller Welding Tools
Most Popular Question
lincoln 140 pro mig welder am useing 35
  • Welding Tools
