20 Most Recent
Hitachi 18V Lithium Ion Cordless Hammer Drill DV18DL Questions & Answers
Just stopped working, recharged battery for 6 hrs still nothing
Measure first the battery if any DC power for between 17 and about 20 v dc come out of it on it its best to let li ion batteries as soon it can be on the charger it has to do with longer lasting of the cells inactiviti can be lead to not accepted by the charger and then it must boosted for the deep discharge protection on the accu its not good to made the battery to be completely empty until the machine stops, no that memory training effect by Nickel Cadmium is of the past. but get another battery to test your Drill and Appeal your warranty if it still applies
Hammer drill will not hammer.
Need a new clutch/tranny. You can find it online - look up tool parts on Google. Tool Parts Direct is a good source. Please rate me
I have a hitachi cordless 18v hammer drill, the
YOU BET, ITS POSSIBLE THAT ITS EVEN COVERED UNDER WARRANTY, THE TOOL HAS A FIVE YEAR WARRANTY ON IT, SEND IT TO A HITACHI SERVICE CENTER, LOOK ONLINE FOR ONE CLOSE TO YOU, ITS A COMPLETE ASSY, YOU CAN ORDER THE PARTS AND INSTALL IT YOUSELF IN ABOUT 10 MINUTES, PARTS SHOULD RUN LESS THAN $50
JIMS TOOL SERVICE
I purchased this drill almost
Hello Blreid, to get the chuck off, you will need to be able to close the chuck. If this means using 2 plumber's wrenches, then so be it. Follow the directions below, and let me know if it works.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting. Remove the battery! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you, and if not, explain what is happening.
How to remove the keyless chuck from a hitachi
The screw mentioned in solution number one is a left hand thread once you have removed it use an allen hey in the hole the screw came out of as if undoing a normal right hand thread a scarp blow with a hammer may be neccesary. then do the opposite when installing new chuck
While using model # ds
Remove the battery and use the eraser on the end of a pencil to clean the battery contacts in the drill. If that doesn't fix it for you, test the battery to be sure it is hot. If all of that does not get you up and running then generally the motor is shot. J.
Hitachi 18v recip saw just quits.....battery life or saw problem?
You are ok with what you got. The cordless saws take a lot of power to cut wood so it drains the battery fast. I have the ridged setup and my battery on a full charge only gets 4 cuts on a 2x4 befor it is dead. The saws will not give you any worning becauase the teath of the blade will get stuck in the wood so it just will not slow down like the drill will. I hope this helps with your ?
Disassembling hitachi 18v reciprocating saw
In addition to the 8 obvious bolts there are 4 more under the gearcase insulator holding the gearcase to the housing. I looked at a schematic for the 18V recip saw and that is all I saw. Have you tried the Hitachipowertools.com website for the schematic? Let me know if you still have trouble.
