20 Most Recent
Porter Cable 60074 Overhaul Kit For FR350 And FC350 Pneumatic Framers Questions & Answers
When driving 3 1/2
It sounds like the air pressure on your compressor is too high..lower it and see if your gun shoots better.
What kind of grease to use on fr350 nail gun for piston o ring
Use white grease or silicone paste. White grease will stay in the gun longer . Silicone paste is cleaner will cost more however will break down with water that enters the gun and will tend to dry out. In either case, the grease will wash out of the gun if you use too much oil on a daily basis. For best results, install an oiler that will introduce oil mist into the gun (not expensive).
I have a porter cable
There are many different brands of nails sold for your gun. Nail companies try to sell nails to fit as many different guns as possible in one box(will range a few degrees). I have found that the stated angle is not always exact. To determin the best nail for your gun, place a strip of nails on the outside of the rails with top of the strip of nails (nail heads) aligned with rails. Now slide the nails forware to the centerline of the path of the driver. If a perfect fit, the first nail will align with the rails and the path of the driver. Note if the bottom of the nail is ahead of the nail head. If this is the case the driver will not hit squarely on the head of the nail. If the head is in line with the driver but the shaft of the nail angles back toward the rails, the nail may jam against the nose. Use your best judgement when buying nails. If you have not had a jam, keep using the nails, however test the nail as described above for good fit. Good luck
FR350 nailer ram does not
Did you rebuild the tool? If not remove all the nails and unplug air, BUMP nose on piece of wood and does driver fall down? If so the pistion o ring needs to be replaced. Also if this is not the case look for a jammed nail in the magazine/nose area. Next check for a bent driver blade. All the above could cause your problem
My FC350 driver was not
The reason it is not retracting most likely is the Piston O-ring itself. I would replace the piston stop of course, but it is not the cause of the initial problem. Let me know if you run into any problems, and I'll be happy to help!
I have a PC Model 136 Belt sander--I know it's
I also have a PC Model 136 belt sander. Although I don't do a lot of woodworking, it has proved to be a workhorse when I needed it. I don't have a problem with breaking belts - the last ones I bought at OSH. The problem that has developed with mine is getting the belt alignment adjusted, after a belt change, to not run against the sander body. A little banging (with my hand) will correct the problem. I have serviced it to free up the fulcrum, but it still jams most of the time.
This doesn't address your problem, but it is good to hear of someone else who appreciates the fine older tools.
Just a further thought - the newer belts I have purchased are bi-directional, e.g., they will run either way. I know that the older belts had to run one way and running them backward could - almost surely would - cause them to break. I won't insult your intelligence to suggest that that might be your problem.
How do i take apart a model 7812 porter cable vacuum to change brushes
The brushes are not replaceable - it is an entire motor assembly.
1) remove the 2 screws holding the top handle on
2) remove the 2 screws on the top of the housing (front either side of switch)
3) remove single screw holding cord hook (rear side of housing)
4) remove small torx screw in the shaker handle and remove the handle
Flip over and using a screwdriver begin to pry the top cover off the housing (easiest to get the front side off first)
Rust in air compressor tank
first you need to remove the tank and get rid of the rust with a rust kill agent, vinga or chemical type with corrosive converter, then liquid paint the inside of the tank, swilling the paint inside and leave to drip out. then find a high pressure line filter, these are a solid filter and put in line. to stop this happening again to the tank you can also put a drop valve in place and when not in use press to release the air inside as this is what rusts the tank. but after the restoration it should be fine without a filter.
How do I unjam a porter cable BN200SB nail gun
I suggest that you make sure that there is no air he tool so, remove the air supply. Then if you remove the cover from the nose (Making sure that you also take out all the unused nails first) it should allow access to the front nose plate. If you remove this, it will allow you to carefully remove the nail. While you're at it, check that the driver blade tip doesn't have any burring or damage to it. If so, you might need to fettle it back into shape or, replace it?
