20 Most Recent
Aerogrow International Inc. AEROGROW AEROGARDEN DELUXE - UPGRADE KIT - BLACK Questions & Answers
Where is the fuse?
The fuse is located inside the base of the Aerogarden 7 on the main power board, and in fact there are 2 fuses. One large 2 Amp fuse, this is easily replaced. There is a second smaller fuse that is hard soddered onto the PCB and is more difficult to replace, but can be done if you have a soddering iron and some patience.
9/2/2010 8:26:55 PM •
Aerogrow...
Answered
on Sep 02, 2010
Buying from thestates
any converter should will work as long as it produces at least a 75 watt output, it really only takes around 50 watts at peak but better to have to much power than not enough. As for someplace cheaper I would suggest you try ecogro.com they are one of my sources for grow equipment and have the best prices. not much you can do about the shipping charge, sorry. Good luck and happy gardening.
Ira
1/24/2009 5:51:26 PM •
Aerogrow...
Answered
on Jan 24, 2009
Change areogrow filters
Filters are located in the bottom, just pop the grow chamber off and there they are.
1/22/2009 6:34:51 PM •
Aerogrow...
Answered
on Jan 22, 2009
Filters
filter is probally on the pump,most pumps pull apart easily
1/5/2009 8:06:15 AM •
Aerogrow...
Answered
on Jan 05, 2009
Aergrow pump
pumps probally blocked,blow air down pump line.run oxy plus or mild bleach though system,rinse in fresh water after
1/5/2009 8:00:42 AM •
Aerogrow...
Answered
on Jan 05, 2009
I have three aerogrow system.
Usually as a result of a power fluctuation all the bulbs could have gone out. First try replacing the bulbs to see if they will come on. If they do then the problem is your power supply get a voltage regulator for all the units as their bulbs are quite delicate as opposed to the conventional light bulbs.
Before trying to tamper any fuses you have to establish that the source of the problem is not external to the unit.
Hope this solution has been helpful?
Thank you for visiting FixYa.
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
Yesterday
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
3 days ago
