20 Most Recent
Sunpentown 2,800 Watt 6.5HP Power Generator Questions & Answers
Need start wheel
There are many generators made in china that use a generic Honda look-a-like motor. If your gen was made in china, good chance that there is an aftermarket starter assembly. Remove the starter and take it to your local small engine repair shop and ask them to try to match it up with another brand. If the starter is missing, take the generator to shop and ask them to look at mounting and starter cup. Good chance there is something out there that will work. If you have the starter assembly, small engine shop may be able to repair. If the starter rewind riveted to fan cover, take the whole fan comer to shop. Good luck
How much gas to oil
Check for a crankcase with oil in it on the motor...if you have oil in the motor already then you do not need to mix it in the gas...
I am very sure that you will find this motor does not need the gas mixed...
Run straight gas... usually it is good to run Prem in small motors..
heatman101
TOOK CARB OFF TO CLEAN
the little spring should go through same holes as the linkage it's purpose is to take the slack out of the rod to keep the engine running smooth a broken spring will cause it too run erratically
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
